Old 04-02-2008, 01:01 PM   #1 (permalink)
EcoModdin' Lurker
Bluey II - '89 Bluebird 2.0iZX
Extreme Idea 'IMA' for almost any car?
A thought I have had for a while, which might be an easy mod for those who want to get an MPG boost without going all the way to building an EV.
The Honda IMA works - by assisting the ICE, and only when the engine is running. It is connected to the crankshaft, on the gearbox side.
However... thinking about it.... it would make no difference if that IMA was actually on the otherside of the crankshaft! (the alternator / air-con pump side). So, therefore, if you got a motor if maybe 7kw max, fitted it somehow to the other side of the crank, and had a button on the steering wheel for manual motor assist, and had a few batteries in the boot, you could make large improvements in MPG. For short journeys, you could charge it at home. Depending on the motor you could also consider using a motor/generator to charge the battery. You could charge it going downhill by leaving it in 5th gear, and coasting with fuel-cut - and have the motor on maximum recharge rate. You could also put some solar panels on the car - 40w of solar panels could give up to 40 watt/hours per hour, or 320 watt hours during an 8-hour working day. This would be a significant amount if your commute was short e.g. 10-20 miles.
Any comments on this idea?
1989 Nissan Bluebird Auto - slowly becoming more economical and more extreme
Old 04-02-2008, 02:35 PM   #2 (permalink)
Slow and easy
elhigh's Avatar
Josie - '87 Pickup
90 day: 30 mpg (US)
I thought the IMA was a 2" thick pancake motor between the engine and the tranny.
You're not in front of me...
I'm 25,000 miles in front of you.
Old 04-02-2008, 03:49 PM   #3 (permalink)
Red
Red's Avatar
Fish - '02 Sebring LXi
Send a message via MSN to Red Send a message via Yahoo to Red
It is, but its just bolted up to the crankshaft. It doubles as a starter, and a generator. If someone justed wanted the extra power boost that an IMA motor could offer, then you could somehow bolt up an electric motor to the front crank shaft pulley or something
Old 04-02-2008, 04:21 PM   #4 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Mild Hybrid
Is this along the lines of a "Mild Hybrid" -- although it probably wouldn't be powerful enough to run the accessories and turn the crank at the same time, like when stopped and such.
Maybe a heavy-duty clutch mechanism could be used to isolate it from the crank -- to sit/idle or EOC, and maintain A/C, Vacuum, Power Steering, etc. Hmmm. Decel charges the system and if the batts die during a trip, it's not a big deal -- de-clutch it and forget about it...
Plug it in when not in use. Good idea landspeed
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 04-02-2008, 05:41 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
landspeed -
I always plug this as a comparison because someone is *trying* to create a bolt-on mild hybrid :
Retrofit Hybrid-Electric System
http://www.sigmaautomotive.com/elect...trocharger.php
The Electrocharger replaces the vehicle’s alternator and battery charging system and gets most of its energy during vehicle braking, while additional energy comes from the engine while the vehicle is at cruising speed. The Electrocharger functions as an alternator at all times, when it is not used as a motor, to provide acceleration assistance to the engine. Power for the vehicle electrical system is provided by a DC/DC converter that can output power for the current 12 volt or forthcoming 42 volt systems.
The Electrocharger system is comprised of a rugged high speed computer-controlled electric motor that is mounted to the vehicle’s engine with a purpose built aluminum bracket. Power and torque from the electric motor is transferred to the engines’ crankshaft via a specialized toothed drive belt that transfers the torque from the electric motor through a vehicle specific sprocket ratio.
The on-board energy for the Electrocharger comes from the Super Capacitor Battery Pack (SCBP) that provides up to 600 amps at 48 volts to the electric motor for acceleration durations. The SCBP is contained in a sealed module that has color coded connectors to ensure proper connectivity. The SCBP is able to withstand the substantial in-rush of current during regenerative braking, maintain the standard vehicle battery state of charge and prolong the life cycle of the SCBP energy storage batteries.
But, they can't get it to work. It has been in development for over two years, .
CarloSW2
American Solar Energy Society
Old 04-02-2008, 06:03 PM   #6 (permalink)
Red
Red's Avatar
Originally Posted by cfg83 View Post
landspeed -
CarloSW2
The IMA does just that though....
Old 04-03-2008, 01:56 AM   #7 (permalink)
Master Modifier
MD2000's Avatar
There are several Mild hybrids that do just what you describe.
I believe the GM Saturn Vue has a 3 phase brushless Motor generator, that replaces the alternator, and assist the gas engine for auto stop/start, and mild acceleration boost.The power runs through a timing belt to the front crank.
Mike Dabrowski
http://www.99mpg.com/
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
Article: Smart car scores hat trick in Canada - now cheapest new car available MetroMPG General Efficiency Discussion 17 02-02-2008 03:41 PM
Article: Smart car offers fun along with fuel efficiency MetroMPG General Efficiency Discussion 0 01-29-2008 08:39 AM
AFS Trinity EXTREME Hybrids!!! cfg83 General Efficiency Discussion 10 01-18-2008 07:15 PM
