Or, on your next fill, just edit the line and enter the updated info (in the meantime, you could put arbitrary numbers in there to better represent you avg).
RH77
__________________ Supporting those devastated by the Joplin Tornado EF5 / 22-May-2011
RH77
Unfortunately I cannot access the database *right now* but try setting the values to 0.
