Old 01-11-2011, 09:13 PM   #1 (permalink)
full wheel covers & brake heat
I'm working with a body shop to do some aerodynamic modifications to my vehicle, one of which is installing aluminum racing discs over the now spoke steel wheels. They were asking me if I had considered the possible problem of insufficient brake cooling - I had not. (My vechicle has all disc brakes.) Does anyone think that this is a problem?
Old 01-11-2011, 09:22 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
It won't be a problem unless you slam your brakes on multiple times within a short period of time. Any decent ecodriver would not heat the brakes up enough to cause problems. Of course there are always exceptions like driving down a mountain...
Old 01-12-2011, 10:08 AM   #3 (permalink)
yea...I'm THAT guy
SL8Brick's Avatar
If you find yourself warping brake rotors and/or going through brake pads quickly, you can always machine some symetrical holes in the aluminum discs for additional cooling if necessary.
FWIW, I used to sell unvented "Kleen Wheels" dust shields back in the `80s. Only a few of my clients had mild brake overheating issues with them. Then again, "Kleen Wheels" shields fit inside the wheel and 'capture' more heat close to the caliper. Granted, all depends on the vehicle & driving conditions but I'd say as long as you're aware of the possibility and remain light on the brake pedal, you'll be ok.
1999 Audi A6 Avant Quattro - 2.8ltr 30v V6/Automatic - 149k miles
1993 Volvo 240 Wagon - 2.3ltr SOHC/Automatic - 323k miles
Old 01-12-2011, 11:54 AM   #4 (permalink)
Ohh snap
brucey's Avatar
Lesbaru - '00 Outback
90 day: 21.98 mpg (US)
Convertalier - '00 Cavalier Z24 Convertible
90 day: 26.08 mpg (US)
Send a message via AIM to brucey
I've driven a loaded, un-braked trailer (4000 lbs of car, 1000 lbs of trailer) through WV mountains with covered wheels without any brake fade. Unless you're racing, I don't think it will be a problem.
Daily Driver
Winter Beast
Old 01-12-2011, 03:15 PM   #5 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
It's really not a problem. I proved it to a friend by finishing a drive and reaching around and touching the brake disc with my bare hands. It was barely warm.
If you're overheating the brakes, you need to change your driving style. Since you're asking about smooth wheel covers, I must assume you've already made that modification, so again - no problem.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 01-12-2011, 06:01 PM   #6 (permalink)
so far so good
So far,I've not experienced any problems.I'm very conservative and drive way ahead,alllow closed throttle engine braking on approach to stops,and am light-footed on the pedal.
Old 01-12-2011, 07:56 PM   #7 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
I have had smooth wheel covers on my car since Aug or about 6-7K miles. Several mountain trips and have had zero issues.
Old 01-13-2011, 10:17 PM   #8 (permalink)
Thanks for all of the feedback! I have about 4 aerodynamic modifications to make, so we will see what the total MPG gain will be. With gas prices threatening to go up, I need all the help I can get.
Old 01-15-2011, 05:46 AM   #9 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 63.49 mpg (US)
Also me no problems with brakes, even when braking down to 0 from high speeds like 160 km/h
First most important four mods would be (my opinion)
- smooth wheelscovers
- Grill block
- belly pan or full smooth undertray
- rear fender skirts
Those dont reguire much skills only time tools and effect should be about 10-15% fuel savings.
www.tuneko.com
Less drag = Less fuel
Last edited by Vekke; 01-15-2011 at 06:00 AM.. Reason: added comment about brake fading
Old 01-16-2011, 12:07 PM   #10 (permalink)
I am planning to do 3 of the 4 modifications that you mentioned. But what is a 'grill block'?
