01-11-2012, 09:11 AM
#11 (permalink)
Shop Rat
You can get around that pretty easy with propane fumigation.
You may want to try a VW K03 turbo with that kabota 950. If I can ever pick up a kabota 950 to build a generator I plan on using one of my K03 turbos on it.
The Kabota with a turbo may be just large enough to try water methanol injection.
Before all this tracker action started, propane was on my list of things to try. What size engine was the K03 used on? I used an IHI-RHB31 on the Yanmar, which is about the smallest one I could find, but still too big. I was thinking I'd use the same on the Kubota. I don't know about the water methanol injection, I'll have to look into it.
01-11-2012, 09:19 AM
#12 (permalink)
Shop Rat
Thanks for all the support, everyone. Yes, my wife is patient.
01-11-2012, 11:42 AM
#13 (permalink)
V8 guy
The K03 was first used on a diesel ford, sub 2.0L diesel engine over in europe that only put out something like 40 or 60hp. In the U.S. the K03 is most well known for being the undersized turbo that comes on the older 1.8L VW gas engines.
It has about a 52mm compressor.
Whats that IHI-RHB31 like?
Maybe it would fit better than the K03 (only problem is I already have 2).
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
01-11-2012, 01:25 PM
#14 (permalink)
Shop Rat
IHI RHB31 Turbo Charger - Vespa Labs
01-11-2012, 02:08 PM
#15 (permalink)
Shop Rat
Here are a few pictures of the engine in the tracker
[IMG]
Engine Mount gas weld 1 by drewski_brewski, on Flickr/[/IMG]
[IMG]
engine, passenger side 3 by drewski_brewski, on Flickr/[/IMG]
[IMG]
engine at firewall by drewski_brewski, on Flickr/[/IMG]
[IMG]
engine at driver's side by drewski_brewski, on Flickr/[/IMG]
[IMG]
Clutch cable bracket by drewski_brewski, on Flickr/[/IMG]
[IMG]
engine, passenger side 2 by drewski_brewski, on Flickr/[/IMG]
[IMG]
engine, passenger side 1 by drewski_brewski, on Flickr/IMG]
Reason: new image url's
The Following 2 Users Say Thank You to DieselDrewski For This Useful Post:
01-11-2012, 02:16 PM
#16 (permalink)
Looks like it's coming along. When do you think you'll have it finished to the point where you can drive it (I realize projects like this are never "finished")? Got a pics of the whole vehicle?
Diesel Dave
~Life is an optimization problem.~
~Who says that just because your vehicle weighs over 3 tons that you can't get good mileage?~
01-11-2012, 02:24 PM
#17 (permalink)
Shop Rat
sort of [if I can get it to work]
1990 Geo Tracker with Kubota D950 diesel (work in progress)
1993 Ford Festiva with Yanmar 2TNV70 diesel
2004 Jeep Wrangler Rubicon with Scangage
2008 Nissan Rogue S
"This is only temporary, unless it works"-Red Green
01-12-2012, 01:34 PM
#18 (permalink)
Shop Rat
Originally Posted by beatr911
You, my man, are seriously committed to these projects. Keep up the good work and please keep us posted of the progress and results.
I can probably speak for 95% of the people here (if I may be so bold) that we seriously envy your skills, tools, workspace and patient wife. You are a fortunate man to tackle projects like this. Keep up the good work!
Any chance of creating a diesel motorcycle?
Thanks for the compliments! I noticed this engine on Surplus Center, it's new to their inventory, I think. It would make a great motorcycle if anyone wants to tackle it. That's not in the works for me any time soon.
2008 Nissan Rogue S
01-22-2012, 10:35 PM
#19 (permalink)
Shop Rat
Recent work has been mostly wiring. I have the glow plugs and fuel cutoff actuator completely wired. I have a little tidying up to do under the dash, then I can put that back together. Then, it will be down to fuel, exhaust, and air cleaner! I opted to be very meticulous with the wiring. (see photo)
2008 Nissan Rogue S
01-23-2012, 07:05 PM
#20 (permalink)
beautiful! more pics and mmore writeup
