Old 05-25-2009, 12:53 PM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
halfbakery: motorcycle pusher for light EV
EDIT from Darin: this thread sprung out of this one, where I showed my towing rig for the ForkenSwift, and posted this picture:
Question, what if you own a motorcycle, and figure out remote clutch and throttle, and use it to push your small EV on longer hiway trips?
Old 05-25-2009, 01:39 PM   #2 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
I love it. Small scale version of:
link: http://www.jstraubel.com/EVpusher/EVpusher2.htm
For the motorbike, all you'd really need is a throttle control and on/off switch. Couldn't you leave it in top gear, accelerate electrically up to speed, then close the bike's ignition to fire the ICE and continue accelerating/cruising?
I don't think the ForkenSwift could handle the weight of the bike (even if only the front portion) cantilevered off the back, like that SUV. Might need a light 2 wheel dolly to put the bike's front wheel in and tow instead.
Halfbakery is so much fun.
Old 05-25-2009, 05:17 PM   #3 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
That Max would easily get squirrely back there and wipe out.
Old 05-25-2009, 06:01 PM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
LOL, well I was thinking more of a 250, in a high gear. And something to hold it by the front wheel a bit better (and hope the forks last). The idea is that is just for cruising the hiway, the electric car still does the driving around town and up to speed. Wouldn't draw any specifics from that pic You want a bike/gearing that is just big enough to keep things moving.
Old 05-25-2009, 06:38 PM   #5 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
I was also going to mention, forks aren't designed to transmit thrust- might want a different mount.
Probably the thing to do is, instead of pushing your EV around on longer trips, just hop on the bike.
Old 05-25-2009, 06:51 PM   #6 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
I think that braking force on forks equates to thrust, but I'd go easy on the cornering.
Old 05-25-2009, 07:44 PM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
Yah, but sometimes folks would want their ev car in another part of the country (i.e. a show, or weather). If you have stuff, or passengers for a long ride it might make sense (assuming you already have a bike and a small electric car)
Old 05-25-2009, 10:50 PM   #8 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
Big flaws that I see are most motorcycles are a wet clutch where the clutch has 5-9 plats and run in oil and have alot of drag, they do this to make them more compact, the transmissions are non-syncro most of the time so any shifting that you did do would be very rough, but you can get electronic shifting kits and ignition cut offs so you can shift without the clutch at all, designed for racing.
The cam on a motorcycle engine is also designed for power not mpg, that is why my 100cc honda can put out 11.5hp, if that was a 1500cc (1.5 liter engine) that would be 172hp and because of that gets 70mpg with a combined cycle and rider weight of 450 pounds...
Maybe make something that looks like a motorcycle rear end, using a shaft drive motorcycle like a gold wing and a better suited engine like a metro xfi, but it's also not going to work with a normal trailer hitch, it is going to need a solid mounting system, I've seen bent motorcycle forks and they are not pretty, most likely bent from alot of hard braking with the front of the bike (900 pound touring bike) as non of the plastic was even scratched, fender was fine, the guy just said it handled "weird"... fork legs looked like bananas.
Old 05-25-2009, 11:39 PM   #9 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
I'm in the process (tedious and expensive I might add) of replacing fork tubes right now. That's why I thought of it.
Old 05-26-2009, 01:27 AM   #10 (permalink)
dcb
needs more cowbell
dcb's Avatar
There are some interesting benefits of using a whole motorcycle though.
1. It should be better sized for the sole task of maintaining hiway speeds than a typical car ICE.
2. It offers complete redundancy. If the car breaks down you have a bike, if the bike breaks down you have a (short range) car. If you are an adventurous experimenter you might appreciate that
3. It should bypass any extraneous licensing. You don't have to license a special trailer that you use once a year if you already own and use a small bike. You don't really have to worry about legalities as the bike is already DOT/EPA, and bike dollies won't draw much attention.
I think the hitching/control issues are completely solveable for someone familiar with the systems intended purpose and who drives accordingly. This isn't anything for production though, just an idea that might be useful in a fairly specific set of circumstances.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 979 12-26-2011 10:37 AM
Range-extender Sidecar for EV motorcycle bennelson Fossil Fuel Free 50 05-25-2009 03:21 AM
MetroMPG.com: Electric pusher trailer MetroMPG Fossil Fuel Free 12 03-25-2009 05:38 PM
Chrysler's New EV Unveiled On CNBC This Morning! rgathright Alternative Transportation 5 02-09-2009 07:54 PM
Extreme Electric Motorcycle conversion for Publicity/Charity bennelson Motorcycles / Scooters 5 11-18-2008 05:09 PM
