Old 12-28-2013, 08:22 PM   #1 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
HID bulbs in Halogen lamps fail govt test
Sorry this is a little long
several posters are altering their headlamps in an effort to reduce the wattage. This is short sighted (no pun intended).
1. it's illegal
2. it provides worse and dangerous lighting.
I had done this research a yr ago for hidplanet.com, a hid retro fit website/forum. Also posted it at FreshAlloy.com.
A popular mod or upgrade today for many owners is in lighting. Specifically Headlamps. HID conversion kits are all over the internet and with prices starting at $40 and claims of ‘increased frontal lighting’, it’s hard not to jump in with both feet.
But are your really getting better lighting?
A recent thread at HIDPlanet.com got me thinking and researching what happens when HID bulbs are installed in headlamps designed for halogen bulbs.
I gathered a lot of my facts from the following site:
http://www.danielsternlighting.com/t...nversions.html
If you want the full test results they are linked at that site in PDF files.
1. It is important to understand that headlamps are designed to meet govt standards.
How ever, each manufacturer goes after those standards in their own way. We see this all the time in various parts of the automobile.
Car manufacturers (since the demise of the sealed beam headlamp) have used 4 basic concepts in meeting the headlamp standard. they use:
Halogen bulb w/ reflector lamps
Halogen bulb w/ projector lamps
HID bulb w/ reflector lamps
HID bulb w/ projector lamps
Each lamp is computer designed around the exact type of bulb and the bulbs can't be swapped back and forth..here is a generic example of a projector lamp:
2. HID bulbs and Halogen bulbs create two completely different light sources.
A hid bulb has 2 hot spots at each end of the light.
a halogen bulb only was one.
since the hot spots are in different locations and generate light completely different, an hid bulb won't work in any halogen lamp (reflector or projector) because the light will hit the inside reflective bowl incorrectly. These hotspots are designed with tolerances in the ½ mm range. As you can see in the picture the HID bulb on the left has it’s hotspot 2mm off from the halogen bulb.
"A halogen bulb has a cylindrical light source: the glowing filament. The space immediately surrounding the cylinder of light is completely dark, and so the sharpest contrast between bright and dark is along the edges of the cylinder of light. The ends of the filament cylinder fade from bright to dark.
An HID bulb, on the other hand, has a crescent-shaped light source -- the arc. It's crescent-shaped because as it passes through the space between the two electrodes, its heat causes it to try to rise. The space immediately surrounding the crescent of light glows in layers...the closer to the crescent of light, the brighter the glow. The ends of the arc crescent are the brightest points, and immediately beyond these points is completely dark, so the sharpest contrast between bright and dark is at the ends of the crescent of light.
This diagram shows the very different characteristics of the filament vs. the arc:
The HIB bulb on the right creates 3-5 times more light. While this is a good thing in a properly designed lamp, it is a very bad thing when put into a lamp designed for a halogen bulb.
3. Part of the Standard 108 that directs the Optical Lamp Engineers is Safety, for the driver and other drivers . And is a major driving force in the design and bulb choose. Lumination in the proper places is a major consideration.
light is designed to be in the correct places so your eyes don't get tired or fixated on a particular spot.
There is also concern that the distance light fades properly. And that the foreground light is not too bright.
I have taken the reports from the above site and created a condensed version (see repots at website for FULL disclosure)
This report is for:
US Dept of Tran., Natl Hwy Traffic Safety Adm
Office of Vehicle Saftey Compliance
Federal Motor Vehicle
Safety Standard 108
Lamps, Reflective devices and assoc eq.
here is the test result. They tested a ORSRAM(a name brand) XENARC D2R 35w. in a halogen reflector lamp.
I have posted the correct halogen bulb results next to the PnP hid results:
THe hid name brand bulb failed in the halogen designed lamp. At some points the light is 20 times too bright!
Here is a visual color chart of the passed bulb and the failed bulb:
Here is another test result from the same web page:
These charts make it very easy to see why ‘converting’ to an hid kit in any halogen designed lamp is just wrong.
the light is all over the place.
Just because there is a Plug n Play Hid conversion kit listed for your headlamp does not mean that it works properly.
Any Hid will make more light that the Halogen lamp is designed for.
Light's effect everyone else on the road. They are designed not to create burn spots in the retina of the other driver. When putting an HID in the halogen lamp you are effecting the safety of the other drivers.
The fact is that any modification of headlamps is illegal. And for pretty good reason.
Here are pictures of a maxima halogen projector lamp with a HID conversion kit:
Notice how uneven the light is.
Here is a picture with the correct halogen bulb:
One of the most important features of a lamp designed for an HID buld is the cut off. It creates the flat line across the light. WHY???? because the hid in a properly designed hid housing can still be too bright for oncoming traffic!!!!
SO if your halogen headlamp doesn't have a cut off, it fails there also.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following 6 Users Say Thank You to mcrews For This Useful Post:
BamZipPow (01-06-2014), California98Civic (01-05-2014), christofoo (01-03-2014), jakobnev (12-29-2013), mechman600 (01-05-2014), UltArc (01-11-2014)
Old 12-28-2013, 10:19 PM   #2 (permalink)
Yupper, even if you car or truck has a projector, that does not mean its approved for hid either. They make those for halogen only as well as hid only.
The Following User Says Thank You to Cobb For This Useful Post:
mcrews (12-28-2013)
Old 01-03-2014, 12:38 PM   #3 (permalink)
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
I removed an illegal HID conversion from my Celica, and installed a legal one. The illegal swap with celica projectors wasn’t as blinding as many reflector swaps you see driving around, but you couldn’t aim the headlights low enough to keep from blinding traffic occasionally. It was worst on small hills. I even used washers to lower the lights even more than the max factory adjustment.
Purchased true factory HID lights off of wrecked Celica out of a junkyard. Also purchased a new level/aim switch from Toyota and all the proper factory connectors. I refinished the yellowing HID headlights with a 3M refinish kit. Finally I built a new relay harness using parts from Waytek Wire.
So the kicker- price. Illegal kits go from $50 to $200 depending on quality, harnesses, etcetera. The used headlights were $450ish, Refinish Kit $20, Level Switch $70ish, Factory Harness Connectors $40ish, Relay Harness Wires, Connectors, Pins, Etcetera used at least $100, ignoring the cost of tools and parts I stocked up on. So obviously more expensive, but it has DOT stamped on it. That is worth something to me.
Another alternative is LED headlights are starting to be available for some vehicles. I have seen sealed beam versions for trucks and jeeps. While those are expensive, considering the potential cost of a legal HID retrofit they don’t seem so bad.
The Following User Says Thank You to aardvarcus For This Useful Post:
mcrews (01-03-2014)
Old 01-03-2014, 02:00 PM   #4 (permalink)
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
As the driver of an irresponsible mod one may not necessarily notice the low beam is not in fact low. If driven primarily in urban settings it may seem to not matter much (streetlights de-emphasize glare). The purpose of the low beam is most crucial on high speed rural highways at night.
On my cars the halogen bulb has two filaments. The low-beam filament sits behind a reflector, part of the bulb, that provides the cutoff, a feature IIRC was irresponsibly omitted by the HID's I pulled up as 'compatible'. EDIT: er, maybe I'm thinking of a 'compatible' LED.
Strongly suggest A-B pictures of your low-beam field on the garage door, arguably also from oncoming POV, if you think you're smarter than the regs and the optical engineers, which is not always totally impossible. But it only takes a certain amount of contamination above the cutoff to make you annoyingly, potentially dangerously, wrong.
The Following User Says Thank You to christofoo For This Useful Post:
mcrews (01-03-2014)
Old 01-03-2014, 02:54 PM   #5 (permalink)
mcrews's Avatar
I agree! W ab testing.
Can't tell you how many post a pic looking at the car and the claim "it's brighter!" Picture usually also shows the light ( really glare) bouncing around the lens!
The correct way is be about 30 feet from a wall. I will post a generic chart when I get to my laptop
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-03-2014, 07:15 PM   #6 (permalink)
mcrews's Avatar
here is a generic chart for adjusting headlamps.
remember ALL HID setup HAVE to have a flat cutoff on low beam.
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-03-2014, 07:27 PM   #7 (permalink)
mcrews's Avatar
this is BAD. If you try to 'adjust it down" then 2 things happen:
1. light doesn't go down the road far enough and you are handicapped at higher speeds where the light isn't far enough in front of you
2. too much light is thrown immediately in front of you and you get night blindness and cant see down the road.
in this picture you can see all the stray light created by having a HID bulb in a halogen designed lamp.
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-03-2014, 08:32 PM   #8 (permalink)
Wow, that is bad. Typically when I see an hid in a reflector lamp it becomes a wide angle flood lamp. Projectors they spread an even flow of light, but the cut off isnt as defined.
Old 01-03-2014, 09:30 PM   #9 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
so, how upset would you be with a guy running Phillips 9012 bulbs in place of 9006?
Old 01-03-2014, 09:38 PM   #10 (permalink)
mcrews's Avatar
9006
9012:
Application notes This new Philips bulb is physically, electrically, optically, and legally compatible with all previous 9012 (HIR2) bulbs, so it can be used for all the same design-specification, replacement, and upgrade applications. It can replace the 9006 (HB4) for special-service use; such a retrofit requires minor modification to the bulb base as described here Like all previous HIR2 bulbs, it does not have a blacked-out tip, which means it should not be used in road going headlamp or fog lamp designs that don't have a bulb shield completely covering at least the top half of the front of the bulb — a ring-style bulb shield that leaves the front of the bulb exposed to the lens is usually not sufficient.
http://store.candlepower.com/ph3rdge90h.html
Goes back to the basic concept. A headlamp is designed for a specific bulb. When you alter the bulb, you will alter the light. they make a point of the black out tip. And I cant tell if the 9012 is a little longer, but by the link, it seems the only issue is the tip/
ECO MODS PERFORMED:
First: ScangaugeII
