Old 11-16-2012, 07:31 AM   #1 (permalink)
Ol' Reliable - '02 Saturn SL2
I hate winter.......
All this cold weather has my mileage in the crapper. My SL2 usually gets between 38-40mpg in the summer when I drive it. Any less than 37 and I'm looking for something wrong; it's just that consistant. :thumbup
Here lately though, I've been struggling to get better than 36-37, despite a VERY concious effort to maximize coasting and accellerate VERY leisurely. It's frustrating to try so hard and drive so careful only to get such a mediocre number.
Anyone have any tip for getting winter mpgs back up? I have done a grill block to help it warm up faster (still takes forever though) and my WAI is pulling right off of the exhaust manifold. Other than that, I'm at a loss other than slowing down to 45mph (not really an option).
Old 11-16-2012, 07:40 AM   #2 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Us a grill block. Block or coolant heater.
I loose 15-20% mpg in the winter no matter what I do.
Old 11-16-2012, 10:02 AM   #3 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
try this http://ecomodder.com/forum/showthrea...tml#post339884
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 11-16-2012, 10:36 AM   #4 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Obvious question: checked your tire pressure? Pressure drops with ambient temperature.
Next: I second the advice to get a block/coolant heater. Makes a difference.
Old 11-16-2012, 11:45 AM   #5 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
I just filled up last night for my worst MPG yet with this car, and I'm convinced it's all because of temperature. I posted in the engine insulation thread that Gealli posted but I will mention it here too. I picked up a fire blanket and put it over the top of my motor. It covers the exhaust and the motor, and definitely helps it warm up quicker.
Old 11-16-2012, 03:53 PM   #6 (permalink)
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
There's one thing we can't fight against, though, it's air density. Air is 10% more dense at -5°C than at 20°C, meaning 10% more drag.
Difference between very hot summers (40°C) and cold winters (-10°C) is 20%.
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
The Following User Says Thank You to HypermilerAX For This Useful Post:
radioranger (12-05-2012)
Old 11-16-2012, 03:57 PM   #7 (permalink)
I have noticed a slight decrease in coasting ability so that does make perfect sense.
To the others: I do check tire pressure regularly. It's been a week or so but temps have't fallen that much in that amount of time. I'd guess them to be at around 40psi (from the 44 I usually run). I'll definately be checking again though.
Old 11-16-2012, 04:02 PM   #8 (permalink)
We can fight it by going slower!
Also colder air is good for throttleless (e.g. valvetronic) engines by virtue of increased heat ratio, but most of us don't have that
Old 11-16-2012, 04:03 PM   #9 (permalink)
The Dirty330 Modder
Gealii's Avatar
There is something we can do...time for more mods to reverse that new drag then come summer we can pull record highs
- Henry Ford
Old 11-16-2012, 04:25 PM   #10 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Accelerate faster to spend more time at your cruising speed.
The Following User Says Thank You to Sven7 For This Useful Post:
