11-29-2017, 08:08 PM
#11 (permalink)
I am sort of obligated to get a truck because i work with a contractor and will constantly need my tool with me ( I have A LOT)
Phrasing? Tense agreement? 19yr-old? C-10? Stance it.
c10 | StanceNation
They came with an inline six. Instead of an in-line motor in the driveline; consider an altermotor from the Buick LaCrosse hybrid. Less volts, less problems.
http://ecomodder.com/forum/showthrea...tor-35003.html
Also — welcome to Ecomodder.
.Two wrongs don't make a right, but three lefts do.
11-29-2017, 09:21 PM
#12 (permalink)
A new model 2wd toyota pickup with the 5spd and a fuel injected 22re will get great fuel economy and you can get a lock box or customize a bedcap for security.
Im only staying with pickups because i assume you have alot of tools and the weight would be counter productive to a car and trailer in terms of cost and practicality.
12-02-2017, 05:59 AM
#13 (permalink)
What kind of work do you do and about how much do all your tools weigh? Even an S-10, Ranger, or Sonoma will carry a half ton. 1000 lbs of tools is a lot of tools.
If nice guys finish last, are you willing to pay the price to finish first ?
12-02-2017, 08:21 PM
#14 (permalink)
Originally Posted by ShodMermaid336
Hello all,
My goal is to have a 350 V8 in front for fun
The 2004-2012 Chevrolet Colorado / GMC Canyon 4 cylinder engine is more powerful than most 60's and 70's SBC's. And the 2WD 5 speed version will get almost 30 MPG with no mods.
12-02-2017, 08:36 PM
#15 (permalink)
home of the odd vehicles
As we chat along the op left after day 1
I guess we’re not female friendly
12-02-2017, 09:12 PM
#16 (permalink)
1+ 4x4 chassie( torsion bar ,they are easyer to keep low) rwd gas, fwd electric . Mount the batteries under the bed inbord of the frame. Doable, expensive, and time consuming. With a 4wd frame you can still drive in rwd wile you are building. At 19 I'm guessing that you have 1 rig so no projects that will take more than 72hrs (standerd weekend) are not aloud without consequences. Conciter a small diesel wv tdi 130-190hp stock. Or a 4bt Cummins backed by a nv5600 or nv4500 130hp tunable to much more . 4bts from bread trucks are a dime a dozen($1500 ebay for a cut frame includs trans ,wires , and evrything in front of the fire wall) the 6bt will fit in a 73-87 chevy by cutting the fire wall. 4bt is tight with all the coolers . Trick is keep the boost down, you should be able to pull 20-30mpg in a full size diesel with a 1000 load ,if you drive it right. If you could swing it +1 one of the new mid size diesel trucks may pay for it self(granted you will be working it for the next 50 years). There is an eco/aero modle Canyon/Colorado ... it is EPA rated at 29mpg. Active grill luvers and about 10 modds for better mpg. A frend got a 4x4 its purity pepy @160hp and 38X ftlb tq has pulled 35mpg hwyfrom the liometer . Basicly the same power in this as my stock 91.5 IC Cummins with 7200 tow J2807 and a lighter pacage.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
12-02-2017, 10:17 PM
#17 (permalink)
Oopsie. No more grammar jokes.
12-03-2017, 01:28 AM
#18 (permalink)
Integrating the electric-assist drive and the engine sounds quite labor-intensive, plus it's quite arguable that you would actually break-even the conversion cost. You could eventually get the engine tuned to a higher efficiency. A more modern truck with an already higher fuel-efficiency would probably be better as a reliable workhorse, unless you're just too fond of the looks of an old C-10. But anyway, considering how the newer trucks grew bigger than their older counterparts, it wouldn't seem to odd to retrofit a C-10 with a smaller engine out of a Colorado, for example.
