Old 12-22-2009, 09:57 PM   #11 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I understand, maybe if you provided some info about indicated and actual refill amounts and related driving style and mileage, something might click.
Old 12-22-2009, 10:31 PM   #12 (permalink)
Will do
Old 12-27-2009, 11:18 PM   #13 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
measuring injector opening
scan data does not measure
ACTUAL injector on time
you can use a high resolution scope .
it is easiest to measure injector open with injector current waveform and it is easiest to measure injector close with injector signal voltage
the open time is about 70% of signal time but varies with different systems
above the Blue trace is Injector current , the red trace is Injector signal voltage - BUT
this waveform was captured using an injector tester pulsing 4ms signals , it is NOT the same as what you will see on a running car / system
BUT
you can see the "gull" in the current waveform which is caused when the magnetic field changes because the pintle has moved opening or closing the injector's opening
an operating system looks like this
pintle movement is clearer and easier to see , this what an actual system waveforms will look like , black is voltage green is current
Originally Posted by smonson View Post
Hi,
I've built a similar gauge for my '99 Nissan Pulsar (which I think is Almera or Altima or something like that in the USA) after being impressed by the MPGuino when it got mentioned on hackaday. My hardware is similar but totally different software.
My question applies to the OpenGauge/MPGuino as well as my thing. Has anyone actually measured the opening and closing delay of a fuel injector? How do we know it's ~500uS? If the opening time is because of the physical movement of the valve, wouldn't there also be a similar closing delay?
Thanks. -Simon
Old 12-29-2009, 12:40 AM   #14 (permalink)
That's excellent information. So for that Volvo the total delay is around 0.8ms - quite a difference from the Bosch one. That definitely looks like the best way to measure the open/close delay for a given injector.
Old 12-30-2009, 12:01 AM   #15 (permalink)
mwebb's Avatar
hmm yes it is but
i think you are looking for total Open time , the delay itself is only part of the equation as
there is a delay in injector pintle closing as well.
you would need to subtract the delay in closing from the delay in opening and then
use software to subtract that total from total injector pulse width
so the software would know
total injector open time
imho
that is BANK injection , where all injectors squirt at the same time
sequential injection will be similar IN OBD1 systems
but
ThrottleBodyInjection waveforms are very different
that value is going to be different on different system s and
if you are not accounting for
asynchronous pulse , extra fuel at the pleasure of the ECM
you probably should
Old 12-30-2009, 09:28 PM   #16 (permalink)
Right. So, if I read the graph axis correctly, 1.6ms opening delay minus 0.8ms closing delay is 0.8ms total delay, subtracted from the pulse width to get the injector operating time.
I'm working on the mathematical approach suggested by dcb now as I don't have a DC current clamp to measure my injector directly.
Old 12-31-2009, 10:19 PM   #17 (permalink)
mwebb's Avatar
1 ohm 10 watt resistor in series to view current
since you do have a DSO
Digital Storage Oscilloscope ?
you can use a 1 ohm 10 watt resistor in series with an Injector
since E=I x R or Voltage equals current multiplied by resistance
if resistance equals one E=I x 1 or E=I
or voltage = current , in that circuit , as per OHM's Law
you can connect your scope test leads across the 1 ohm resistor in series with an injector
you will see the SAME current image that i posted for your injector
in voltage
sequential injectors use less than 1 amp so set scope scale to 0 to 1 volt at about .5 ms per division to start then adjust to see image full screen .
place your cursors to get your actual injector on time
The Following User Says Thank You to mwebb For This Useful Post:
dave77 (01-06-2010)
Old 01-03-2010, 08:16 PM   #18 (permalink)
Thanks, I know how electricity works. I don't want to go disconnecting everything in the middle of collecting some mileage data, but if I can't get an accurate result this way I will try a current measurement.
The Following User Says Thank You to smonson For This Useful Post:
dave77 (01-06-2010)
Old 01-06-2010, 01:18 AM   #19 (permalink)
Here are the results of my observations
The following maths treat all cylinders as a single measurement. Figures will be 4 times higher than the real value for a single injector.
WARNING: PEDANTIC GUY AHEAD
Tank 1 (country):
- predicted 28405mL
- actually 28360mL (error: 0.15%)
- PWM fired 332468 times for 2195.598 seconds
- average pulse width: 6603uS
- average fuel quantity injected: 85.301uL
Tank 2 (city):
- predicted 30954mL
- actually 30950mL (error: close enough)
- PWM fired 385078 times for 2403.540 seconds
- average pulse width: 6241uS
- average fuel quantity injected: 80.373uL
The difference in pulse widths is 362uS and the difference in fuel injected is 4.928uL. From this we can infer that the fuel pumping rate is 0.01361325 uL per uS. Converting units, that's 204cc per minute which is in the expected ballpark for a small car.
The total time to transmit the average injected fuel amount into the cylinder is then 6266uS (tank 1) or 5904uS (tank 2). This predicts the injector time delay at 337uS for both, depending on how inaccurate those particular fuel pumps were.
Thanks dcb and everyone else for all the advice!
The Following 2 Users Say Thank You to smonson For This Useful Post:
dave77 (01-06-2010), t vago (02-04-2017)
Old 01-06-2010, 08:31 AM   #20 (permalink)
dcb
needs more cowbell
dcb's Avatar
put your car make and model somewhere so folks can use that info pls.
The Following User Says Thank You to dcb For This Useful Post:
dave77 (01-06-2010)
MPGuino for Audi rmccomiskie OpenGauge / MPGuino FE computer 40 05-22-2011 09:18 PM
Canceling out pumping losses of throttle governed engines greasemonkee EcoModding Central 60 08-03-2009 04:24 PM
Actual mpg vs % that mpguino is off wagonman76 Instrumentation 5 04-17-2009 07:41 PM
