Old 12-11-2009, 09:36 AM   #1 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Lotus developing HCCI engine, claims 10% efficiency increase
Interesting to see Lotus doing work on efficiency related items, but it seems they are working on their own gasonline HCCI (homogeneous charge compression ignition - ah la diesel) engine. Its also claimed that it can run on almost any liquid fuel because it has variable compression ratio via a movable puck the the head.
Lotus: Omnivore engine is 10% more efficient with more to come - Autoblog
Old 12-11-2009, 11:43 AM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...a compression ratio "puck"?
...I've wondered why two "opposed" cylinders with variable "timing" on the dummy-compression piston hasn't been popularized more...especially with today's smart ECU controllers.
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
Old 12-11-2009, 12:41 PM   #3 (permalink)
Pokιmoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Daox -
I'd like to see a comparison chart between that one and the one that GM has had "in the works" for a really long time. It sounds like Lotus is claming to solve the HCCI puzzle.
CarloSW2
American Solar Energy Society
Old 12-11-2009, 01:48 PM   #4 (permalink)
CM400E - '81 CM400E
That would be great to see. How long has GM been working on their HCCI anyways? I know its been quite a few years, but unsure of exactly how long.
Old 12-20-2009, 04:46 PM   #5 (permalink)
Ethanol Fan
Mr. Fox - '91 Mustang GT
90 day: 15.99 mpg (US)
Cool
Traditionally 2 stroke engines generate 50% more power and use 50% more fuel than 4 stroke engines. If they eliminate the fuel usage problem inherent in 2 stroke carbs that give it such terrible emissions then it sounds good to me. Having a working prototype is probably Lotus' main point. But increasing compression from 10:1 to 40:1 is pretty handy. 10% improvement on Gasoline means if it ran on Alcohol or Diesel it could be even better. Mixed with turbocharging we're talking about cutting engine sizes in half and then by a third. Which means a theoretical 2.0l engine could be replaced by a TurboCharged 660CC motor! And run on just about any fuel of your choosing.
Mixing oil with gasoline is obsolete already since they switched most 2 strokes here in the US over to wet sump years ago. Some of the comments, sheesh .
~Allch Chcar
Old 12-21-2009, 12:31 AM   #6 (permalink)
wdb
lurker's apprentice
Scootie - '08 Fit Sport
90 day: 37.19 mpg (US)
Yeah, really. But then I thought about it a little bit and realized it wouldn't be that hard to do. All you need is a bit of moveable real estate on the cylinder head side of the combustion chamber. Move it further into the chamber to increase compression ratio, and move it out of the combustion chamber to reduce it. It can't be a flat plate, it needs to have sides; make it round and you have a "puck".
Old 12-21-2009, 11:52 AM   #7 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
I have one of those, a two stroke diesel model airplane engine that fits in the palm of your hand with a nob on top to change the compression.
Old 02-03-2010, 03:34 PM   #8 (permalink)
janvos39's Avatar
FKB - '03 Focus DAW/FFDA1/5PFDMW
90 day: 45.7 mpg (US)
Lotus new development engine
An engine developped by Lotus for mixed fuel ,variable compression, two stroke, high efficiency.
Run the engine
http://www.grouplotus.com/manageshow...sthru/8628.swf
The Following 4 Users Say Thank You to janvos39 For This Useful Post:
NeilBlanchard (02-03-2010), Old Tele man (02-03-2010), Piwoslaw (02-06-2010), wdb (02-05-2010)
Old 02-03-2010, 04:46 PM   #9 (permalink)
...beats walking...
...excellent technical illustration of "...what's going on..." but I have to worry--too many mechanically 'moving' things for my mechanical-comfort-zone.
Old 02-05-2010, 01:34 PM   #10 (permalink)
wdb
lurker's apprentice
Maybe you've never seen how the various VTEC systems work. They can be pretty complicated, and people routinely get multiple 100K miles out of the engines.
I'm fascinated -- and a bit confused -- by the exhaust port Trapping Valve.
Restore oil additive... suspectnumber961 The Unicorn Corral 43 05-14-2010 03:40 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
Automotive X Prize - would a modded Civic VX make it? Krieg EcoModding Central 31 01-02-2008 07:06 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
