Well... I didn't think I'd ever be makin' an ebike thread - but here I am heh
A little background on this first I s'pose, I've been tinkerin' away on a suspended hybrid/tribrid tadpole trike on & off for about a year now:
The Bent Zombie Tribrid Tadpole Trike & it occurred to me that it's electric drive was not only untested, but I was not terribly familiar with ebikes - the only one I'd ever had was years ago, a 12v SLA friction drive
'Zap' setup that was honestly a bit ridiculous, anemic to say the least it's woeful lack of power combined with it's incredibly limited range wasn't complemented by being a friction drive.
Fortunately, I held no grudge against the ebike concept because of it lol, even then I knew full well that wasn't a realistic system for anything other than the novelty factor.
Still, I figured I needed some time on a "real" ebike to see what I was getting into with the tribrid, I didn't have enough experience to know if it would be even worth the bother or what the problems may be - combined with the fact I needed a replacement commuter & winter beater I picked up a
Mongoose Snarl mountain bike w/dual disc brakes to test out the electric drive (come winter it'll get an in-frame 2 stroke).
The bike itself is surprisingly good for the price ($250) with beautifully fat, nicely lapped weld beads, 100mm travel forks w/adjustable preload and ofc the disc brakes, which while generic - actually have a centering adjustment feature. The rims themselves are unsurprisingly just the typical single wall alloys w/14ga spokes - those will be replaced & I've ordered some low cost ($22ea) fatty double wall rims w/that in mind:
Weinmann Disc Bull Rim 26 x 2.00 36 Hole Black along w/another pair of my favorite cheap ($17ea) tires:
Cheng Shin C1218 street tire, 26x2.125 - which w/a harder compound than you'd expect w/semislicks & very thick tread area, have proven to be very puncture resistant, durable tires that handle great.
The only actual disappointments w/the Mongoose 'Snarl' (other than it's silly name ofc lol) is it's kickstand is about 3/4" too short even w/o the added weight of motorization (it's b'cause of the long travel forks) & the stock seat is by far the
most uncomfortable thing I've ever sat on - I suspect a splitting maul just might be worse, but I'm not going to experiment w/that to see & I just stole the comfy sprung seat off my old Stokvis for now.
BTW, while mine is a 26" (for the hub motor & wheel I already had), the Mongoose 'Snarl' is also available in a 29" if you're interested, I did a quick test fit w/a in-frame 2 stroke and it seems to fit w/o issue (knowing it's aluminum w/an oversized down tube ofc), but I should mention that w/these forks, even the 26" is a somewhat tall bike & you may not want the 29" if you're "vertically challenged" - I'm a hair over 6' and even the 26" is taller than I'm used to.
Anyhoo, on to the ebike stuff heh - to mount the
Golden Motor 'Magic Pie' 48v 1000w hub I had to open the drop outs just a hair for it's oversized axle... not so much even "widen" them but smooth them just a little to allow the flat-faced axle to slide up & in there (prevents torque rotation). The only problem w/that is as the axle is slightly larger the disc rotor doesn't quite go all the way up into the caliper anymore, it's about 1/16" short of the edge of the brake pads which will cause uneven wear w/a "lip" developing on the pad. I'll hafta fix that ofc... but I'm going to wait till I've my new rims built. I'd already made a rotor spacer for the tadpole as it's caliper (Avid BB5) was too close to the hub - coincidentally & very fortunately the spacer jus' happened to be perfect for the Mongoose's caliper too so I didn't hafta mess w/that anyway.
I then stole my poor Schwinn's rear rack, which I'd already modified w/vertical supports to the dropouts (it was a seatpost clamp only design), bolted it up to the Mongoose (just needed one spacer for a support to clear the rear caliper) with a set of
M-Wave Double Day Tripper Bicycle Panniers ($25) for the
48V 15AH LiFePO4 battery packs to go into. The M-Wave panniers are lined with plastic panels so while they're not "collapsible" the panels serve to spread the weight evenly. I'd custom ordered the LiFePO4s to be split into two battery packs for the tadpole, which has worked out well for this too - I just can't see having 16lbs mounted to the top of the rack like I'd hafta if it was a single pack... even split into two & mounted lower the handling w/the weight back there is noticeably... different - not bad, but defo different. I s'pose I'll get used to it, I'm just glad it's not the 30+lbs of SLAs lol
Then it was jus' a matter of routing the wiring & handlebar controls & I was ready for the first test ride - which went well for about 45 minutes, then things started to go badly...
very badly. I started loosing connections, the throttle, the main power leads & the hub (internal controller) started beeping error messages - sometimes, when it felt like it... and it just kept getting worse until I had nothing at all.
Knowing all the secondary connectors (throttle, cruise control etc) were cheesy, flimsy little bits with wiggly pins - I figured I had a loose connection somewhere & started my diagnostics. Interestingly, while those connectors are sad, pathetic lil things they weren't actually the problem... or problems as it turned out & thus began my three day headache of sorting out what the heck was going on.
First the main power plug had an intermittent failure on the negative pin (left plug in third pic) an easy fault to find & even easier to fix w/a new, far better connector, I'd already gotten a
Delphi Weatherpack (weatherproof connector set) for the taddy's harness so I had a plug handy. The hub then worked fine... for about 5 minutes & then quit entirely again. This was a major setback as it obv wasn't the main power plug anymore I had to do continuity tests on the rest of the wiring - and the ends of those wires are ofc inside the hub, being a "spiffy" internal controller and all. This meant I had to pull the hub itself apart and
that's no easy task as the side covers act as the armature's housing (centering & bearing mounts) and ofc it's sealed to protect the internals from the wet.
Searching around online I found only vague references to the disassembly procedure & what I found just couldn't be right - it was suggested that after removing all the fasteners from the cover to "pound on the other side of the axle with a mallet" and that "should free up the other side's cover" ...while I may be an ebike novice, I'm no stranger to electric motors or wheels & bearings for that matter and that recommendation filled my brain with horrid images of bunged up bearings, mangled C clips and other, even less pleasant suspicions. Fearing the worst, I just made my own puller - much like any gear/pulley remover it bolted into the brake rotor mounts and applied pressure to the axle, removing just the cover on the same side.
With the cover off finally many things became apparent - first, I would have done a number on the sealed bearings & retaining clips had I followed that "advice" & second, they were decidedly stingy with the solder... everywhere. Now able to do continuity tests I found that the main junction block (where all the separate wiring joins to become one cable, to then go into the axle) had faulty connections, problematic as it's a solid chunk of molded plastic (third pic, thing on the right). I tried for a while to gently cut it apart, but after succeeding only in cutting me apart I simply removed it and made my own (forth pic), after cleaning up the mess I made of my thumb ofc. Then I resoldered all the internal connections so I wouldn't hafta go in there again. While it isn't mine (I was too cranky for camera crap at that point), the fifth pic shows the internal controller, complete with it's shoddy soldering. Apparently this is common as every pic of the internal controller I found had similar issues, there's more examples here in the Mongo's
photobucket album.
...so oddly, after replacing & resoldering all the connections
except the ones I thought cheesy - everything tested out just fine... ok whatever, I can accept that lol, I've long distrusted electronics so I'll jus' chalk this up as another example why heh
I then reassembled everything again for another, hopefully more successful test run. I swapped out the lightweight tires the bike came with with the heavier duty tires the Schwinn was sporting, which turned out to be a mistake on my part as I hadn't noticed the sidewall damage from the Schwinn's maladjusted rim brakes & ended up with a wobble from the rear tire's broken belts. Oh well, just an excuse to get those spiffy new tires right?
Everything seemed to work well running it around the parking lot so I trusted it to get me to work, taking over the daily commute the now stripped Schwinn so faithfully ran for so long. Cruising a sustained 23, with a 25mph max (flat ground) and with decent acceleration I don't actually have to pedal to get started - I usually do anyway tho to lighten the load on the motor & battery reserve. After a coupla days of this and some playing around, I decided to do my weekly grocery run with it and that too went so well even laden down w/bachelor chow I decided to do a 15 mile lap just to see if that would make a dent in the seemingly endless battery reserve... and according to the (admittedly questionable) battery level lights on the throttle - it didn't, but there was no loss in power that I could see and as my lil
2A charger only took roughly two hours to top off the battery packs... I can only assume there was still quite a reserve. So this weekend I'm hoping to try twice that - to attempt a thirty mile trip, weather permitting ofc.
All in all I've really mixed feelings regarding the Golden Motor 'Magic Pie' setup... while it was a nightmare of shoddy soldering & cheesy connectors, with only very basic repairs it's turned out to be a decent hub drive that's
very feature rich, the only other issue is the rim wasn't trued properly, but that's not unexpected w/any wheel purchase. Given it's relatively low cost ($240 for hub & wheel w/controller) I can't really recommend against it as it should be a really easy, simple ebike kit for the novice yet still having all the "bells and whistles" such as integrated lighting & horn, cruise control, true and adjustable regenerative braking, variable voltage compensation, anti theft, etc., etc., even reverse... not that such is needful with a bicycle lol
Thing is, I can't really recommend it either given the problems... I do suspect it would have been covered by the warranty had I tried it when I first got the thing and sent it back, Gary from
Golden Motor Canada is reportedly good about such - but I didn't bother as I made the purchase about a year ago & I didn't feel like bothering with S&H and the wait times *shrug*
Anyway, here's a movie of some of my fifteen mile test run, just the four miles of the only bike path around here... I don't run the path with my stinky, loud & fast gas bikes, but I figured it'd be OK with the stealthy "clean" ebike lol, besides it was freezing cold & 6am - I figured there wasn't going to be many other riders, and there wasn't
