Old 11-20-2009, 08:23 PM   #1 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
MPG Decline from Colder Weather or Winter Blend Gas or ???
Hello -
From around the beginning of October, my fuel log tanks have been in the tank. One reason could be that I am refreshing some parts on the car in an attempt to improve my emissions (new 02 sensor, new EGR). I didn't reset the ECU/PCM to relearn because I wasn't sure if it was a good idea or a bad idea.
Now I am seeing my MPG on the decline. One reason is obviously the weather, but I wonder if the "winter gas" thing is effecting me. I was of the thought that I didn't get winter blends in Los Angeles, but now I think I do get the winter blend (probably because it's cheaper to make) :
What is summer-blend gas? - By Sam Schechner - Slate Magazine
Summer-blend gas isn't new. It was first sold in 1995, as required by the Clean Air Act's 1990 amendments, and the current, even cleaner, concoction was phased in for the summer of 2000. Since then, there have been sharp spikes in fuel prices every spring as summer blends get rolled out. This is not so much because it's expensive to make the gas—the added cost per gallon is only 1 or 2 cents—but because refineries generally try to sell every last bit of winter fuel before mixing in the slightly more expensive summer batch. Sometimes they draw down the stock too far, creating shortages before the first deliveries of summer blend enter the supply chain. The return to normal blends in the fall causes a far less pronounced spike because the industry, free from summer standards, doesn't bother selling off the summer gas before mixing in the less pricey stuff.
So why not use the summer blend year-round? The main reason—apart from the fact that the 1990 law isn't written that way—is that summer-blend gas doesn't work as well in the winter. Summer blend's low-evaporation rate makes engines less likely to stall in hot weather but can make them difficult to start in the cold.
Anther forum talks about same subject :
Summer Gas Blend & Better MPGs - Maxima Forums
- It is cheaper to make winter grade gasoline because it is possible to blend more butane into the fuel than you can in the summer, when you essentially can not use any Butane in gasoline. Butane is relatively cheap and has good octane properties. It also greatly helps an engine start when the temperature is 10 degrees below zero.
So, I guess I do get winter gas, but I am not sure *when* I get winter gas. I did a 2008/2009 comparison, where I looked at 2 month intervals before/after October 1st :
So, from the above, in 2008 I lost 0.81 MPG after October 1st. In 2009, over roughly the same time period, I lost 2.10 MPG. That's over 1 MPG different.
Maybe I will do a weather analysis to see if there is a big difference between 2008 and 2009. Also gotta look up what mods are there/not there from last year.
CarloSW2
American Solar Energy Society
Old 11-21-2009, 01:01 PM   #2 (permalink)
winter losses
The SAE used to allow for up to a 3-mpg loss for winter operation.
Viscosities are higher at the lower ambient temps and even after 22-miles of continuous driving to reach equilibrium the viscosities are still higher than in summer.
It's a rough time for testing mods,as actual results may not be reflected until next spring.
Old 11-21-2009, 03:33 PM   #3 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
There's a well-written list of a dozen or so reasons your fuel economy drops when the weather gets colder, floating around the forum somewhere, but here's a quick list off the top of my head:
Winter gas has less energy per gallon. The viscosities Aerohead mentioned mean that every bearing and fluid in your car requires more energy to move. Cold air is denser and harder to push out of the way, increasing aerodynamic drag. Your ECU will run the engine richer and probably idle higher. The air in your tires has contracted and you'll have to add more to compensate.
The optimum fuel economy weather is: dry, and as hot as you can stand without using the A/C or opening the windows.
Old 11-21-2009, 05:01 PM   #4 (permalink)
Driving the TurboWeasel
Ditto. My best FE ever came on a 100-degree day. I believe I downed 2 liters of water in 2 hours it was so hot in the car.
2012 Chevrolet Cruze Eco 6MT
Old 11-23-2009, 12:30 PM   #5 (permalink)
sukisuki - '00 Grand Vitara 4wd
90 day: 21.88 mpg (US)
Get a fuel warmer...
Old 11-23-2009, 01:12 PM   #6 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
1989 Chevrolet Celebrity CL 4 door Gas Mileage (Red Car) - EcoModder.com
My fuel log shows the same thing, a considerable drop right at the beginning of October. I can't say it's due to weather and temperature, since most of the summer was pretty horrible for weather and most of the fall we have have a lot of the nicest days of the year. It could very well be winter gas.
I do agree that my best mpg came from the handful of 70-80F days we had this summer. I even got 40 mpg going home from work 2 or 3 times.
Winter daily driver, parked most days right now
Summer daily driver
Old 11-23-2009, 02:49 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Hello -
Thanks for the tips. I think the weather has definitely been an important component. I went here ... :
California Data Exchange Center - Query Tools
... And looked for weather data for the same time period 2008 vs 2009. It was difficult because there are a lot of weather stations, but there is also a lot of missing data for this time period. I eventually had to settle for San Rafael Hills, which is North of downtown Los Angeles.
CSV Data Retriever: SAN RAFAEL HILLS (LOS ANGELES R)
I used the "TEMPERATURE, AIR AVERAGE (deg f)" data to build this graph (from August 1 to November 22, 2008/2009):
The keys are the thick flat monthly averages. October 2009 was about 7+ degrees colder than October 2008. This implies to me what I was hoping for. My October/November 2009 has been much colder on average than the same period in 2008.
This makes me happy because, hopefully, the emission-cleanup mods I have been doing were not the culprit.
CarloSW2
Old 11-23-2009, 10:15 PM   #8 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.92 mpg (US)
I think the reasons discussed are all true.
What to do about it?
My gas log seems to show I'm doing a few mpg better than this time last year. I credit two things:
1) I recently uncovered the upper block and got a good rise in intake air temperature. The upper grill slots are small but apparently the intake air flows through them and thru the radiator before getting sucked into the filter box.
2) Lower grill is the big one on my Civic and I've carefully blocked off most of it with chunks of foam pipe insulation wrapped in duct tape. With that done I've been able to run some cabin heat and still get good engine temps. I watch the coolant temp on ScanGauge and I don't generally open the heater valve till its fully warm. Warmup just takes so much longer if you start heating the cabin early.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Old 11-24-2009, 03:49 PM   #9 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
brucepick -
Yeah, I am going to modify my grill block setup for my "LA winter". I think I will also work on an undertray ahead of the front wheels. My problem is that it is pretty easy to put the car in the overheat zone. When that happens, it costs me up to 30 Amps to run the electric fan.
I checked and found my PSI down on all my tires in the range of 42-45 (me lazy), so I upped it back to 50 today.
CarloSW2
Old 11-24-2009, 07:38 PM   #10 (permalink)
Left Lane Ecodriver
cfg83, is 30A the rating of the fuse/relay, or the actual power draw? If that's the actual power draw, it costs you the better part of a horsepower. That's a whole lot, but it's very low duty cycle, while the aerodynamic benefit of a better-blocked grille is continuous.
Winter is coming, and I'm thinking about stepping up my game with a block heater, and grid-charging of one or both batteries. Plugging in and colder weather seem to go hand-in-hand.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
40 mpg on winter formula gas. EXPIOWA Success Stories 1 01-20-2009 10:37 AM
What's your best bet for an automatic? Crono EcoModding Central 16 10-22-2008 01:14 PM
Decline in U.S. summer gas use expected for first time in 17 years SVOboy General Efficiency Discussion 13 06-03-2008 09:58 AM
