Old 04-30-2013, 03:24 PM   #21 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
stewie:
the latest # I have tried is 258562433 it seems to be the closest I have seen, I have only run it for 100 miles tho so a full tank may be off a bit.
In the mean time I have altered all my gaslogs to adjust for the tires size.
2000 Insight MT 106K Citrus A/C
The Following User Says Thank You to WD40 For This Useful Post:
stewie (05-01-2013)
Old 04-30-2013, 04:10 PM   #22 (permalink)
stewie's Avatar
Milano Red VX - '92 Honda Civic VX
90 day: 50.15 mpg (US)
WD40 sweet bro. You're great man! How does your ODO mileage compare to Guino mileage after tire adjustment? the gal/sec number you want is probably that matches or is closest to those ODO match after tire mileage adj with Guino mileage. I'll put in some input as well after i get it installed properly this weekend. We'll figure this out. I really do appreciate your and Andrzej input. I have a starting point with your figures to tweak it now where wiki number was so off i would spent a month or more on getting it right so for that WD40 i thank you much. BTW what is our tires PSI if i may ask. I just bumped mine to 45psi. Max i can do is 50. In winter i ran 34psi. My goal is to run 50mpgs or plus constant which i can only do occasionally now.
Old 04-30-2013, 05:14 PM   #23 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Originally Posted by stewie View Post
Andrzej you're the man! Thank you. I found ISP port on the board. Is that the serial port in need to use to get into chip? How do i do that? Is there a guide for doing this? Are there any other functions that can be added to 0.86 guino as well. What would i use RPS for in terms of calibration?
There are many things you can add to MPGuino, right now I'm working on temp gauge, range gauge (how many km/miles you can ride with current FE and given tank size), and coast down time and distance meter.
If temp gauge will work as it should I think I'll include temperature management system into it. My guino will close & open grill accordingly to engine temp. Or I'm hoping it will
Anyway when I get my code working I'll post it here and maybe I'll add it to MPGuino wiki. Problem is that I'm working with "canadian" version, but code is very similar so it shouldn't be hard to include those changes into v0.86 "official" code. Maybe I'll make two versions of my code changes for canadian and official version. If there will be someone interested
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
stewie (05-01-2013)
Old 04-30-2013, 05:19 PM   #24 (permalink)
WD40's Avatar
Gen-1 Insights
stewie:
I ran my tires as high as 65 psi but there is no noticeable difference in MPG between that and the 50 that I run now.
The big difference is less road noise and bone jarring.
stewie (05-01-2013)
Old 04-30-2013, 05:24 PM   #25 (permalink)
AndrzejM's Avatar
I forgot to answer your question. Yes you can upload changed code using ISP, and simple serial or parallel to ISP cable. Or using any Atmel compatible ISP programmer.
My MPGUino I've build on my own using Arduino. Good thing is that I can make any changes I need and it's much easier with all the ports available.
Old 04-30-2013, 11:17 PM   #26 (permalink)
Small note on your rpm code:
The "RPM" and "rpm":"rpm" is redundant. An improvement would be:
void doDisplayBigRPM() {bigNum(instantrpm(), "RPM", "");}
or
void doDisplayBigRPM() {bigNum(instantrpm(), "", "RPM");}
Originally Posted by AndrzejM View Post
Code changes for v0.86 to have Big RPM gauge
The Following User Says Thank You to nickdigger For This Useful Post:
stewie (05-01-2013)
Old 04-30-2013, 11:50 PM   #27 (permalink)
stewie's Avatar
Andrzej thank you. Still will need to research into how to do that. Found some cool info.
Mpguino_calibration
http://ecomodder.com/wiki/index.php/Mpguino_calibration
Injectors explantion...middle of the page
http://combustory.com/wiki/index.php/MPGuino#Enclosures
Code hacks
http://ecomodder.com/wiki/index.php/Code_hacks
Programmer
http://www.ladyada.net/make/usbtinyisp/index.html
Old 05-01-2013, 11:23 AM   #28 (permalink)
stewie's Avatar
Guys i did test drive today (with 500 miles numbers from WD40) and downloaded app with decimal speedometer with multiple sats. So Guino reports speed under (within .30-.50mph) and miles (within .40-.60m) under GPS so i guess i'll have to tweak those numbers as they appear off which would explain the mpgs being off.
Old 05-01-2013, 12:00 PM   #29 (permalink)
WD40's Avatar
Gen-1 Insights
stewie: please let me know what #'s you come up with that I can test on mine.
I've just gotten used to close enough for settings, but closer to perfect is always welcome.
also please join team honda http://ecomodder.com/forum/team.php?id=1
Old 05-01-2013, 12:30 PM   #30 (permalink)
stewie's Avatar
also please join team honda EcoModder Team Competition
WD40 i am extremely thankful for you providing me those numbers. They are close. Main thing is to get miles right to GPS miles. I'm trying to figure this out.
Andrzej how do we tweak speed. I think that should be accurate as guino taps into Vehicle speed sensor. Does VSS gets adjusted from those two variables we provide or mph is provided from VSS as static value?
