Old 08-09-2008, 02:25 PM   #21 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
still anxiously awaiting for the idino to be delivered.
Received the lcd about a week ago, already picked up all of the other parts on the list from local electronics supply house.
Still very excited; but will be out of town without the golf for 2 weeks starting on Friday, I hope it comes together by then; if not I may bring it all with me to assemble.
6 speed ALH TDI
Old 08-30-2008, 09:34 PM   #22 (permalink)
6 speed Diesel FTW!
Diesel
My dino JUST showed up (In between my last post and this one).
I do not have time to Assemble it here; however I will be evacuating with the kit (and HOPEFULLY al the parts) I will try to get it together on my forced vacation.
6 speed ALH TDI
Old 09-14-2008, 02:36 PM   #23 (permalink)
Hi fellow TDi-ers
I have an Audi A2 1.4Tdi which ScanGauge doesn't want to talk to, so I'm very interested in joining in with the TDiguino build & test.
I'd like to order the parts ASAP, but I'm based in the UK & would prefer to either get everything over here or get everything shipped as one consignment from the US to save on p&p - are there any UK based members who can point me in the right direction or is anyone producing kits yet?
I'd be willing to pay someone a few bucks for their time to gather all the parts together for me & ship them out - any volunteers?
Eamonn
p.s. dremd - hope the forced vacation went ok
Old 02-28-2009, 01:53 PM   #24 (permalink)
Below is the MPGuino installed in my '96 Passat TDI:
This pic was taken in the early stages of calibration, so its reading a bit optimistic.
Many thanks to dcb and rmccomiskie for their helpful posts on this subject.
What I ended up doing is tapping into the ECU fuel consumption signal as a substitute for the lack of a 12V injector lead in a TDI. The ECU fuel consumption signal is a "negative pulse" which requires a minor change to the MPGuino code:
Change:
attachInterrupt(0, processInjOpen, FALLING);
attachInterrupt(1, processInjClosed, RISING);
To:
attachInterrupt(0, processInjOpen, RISING);
attachInterrupt(1, processInjClosed, FALLING);
Again, thanks to rmccomiskie and dcb for figuring this out - it would have taken me a whole lot longer (if ever) without their help.
I tapped the VSS and fuel consumption signals at the instrument cluster plug. A Bentley manual is very handy for identifying the wire #s. On my Passat, it was wire 26 and 27 IIRC. Green and white wires spliced in below:
I procured an ashtray from a salvage yard Passat and cut a hole in it to make a somewhat stock appearing enclosure. Since the cigarette lighter was nearby, I tapped the constant 12V here.
With about 50 miles on the MPGuino, it looks like it's going to read fairly accurately. I had a 98 Jetta TDI with scangauge and the instant MPG readings on the MPGuino look fairly consistent with what I used to see with Scangauge - i.e. Idle shows ~0.17 GPH, coasting in gear 0 GPH, steady 60 MPH cruising shows 45-50 mpg on flat ground, 5-20 MPG while accelerating or climbing hills.
I'll post back with my calibration settings when I get a few more test miles racked up.
Old 02-28-2009, 02:18 PM   #25 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Awesome
Did you leave in the injector delay?
I wonder if DREMD has noticed?
Awesome
And props to rmccomiskie for bringing up the vw/audi signal!
Old 02-28-2009, 03:11 PM   #26 (permalink)
6 speed Diesel FTW!
Diesel
I did notice!
I SO wish I had done this first; it has been bugging me since I got the parts.
I'm VERY glad somebody else stepped up to the plate!!!
6 speed ALH TDI
Old 02-28-2009, 03:16 PM   #27 (permalink)
Yes, I started off with the injector delay at 100uSec based on the oscilloscope graphs of the fuel consumption signal posted by rmccomiskie. I also briefly switched it back to the default setting of 500uSec to see if the MPGuino would generate the same erratic readings noted by rmccomiskie when he used the Audi FC signal. My GPH readings were stable with either delay setting, but I switched back to 100uSec for now.
Old 03-01-2009, 10:07 AM   #28 (permalink)
6 speed Diesel FTW!
Diesel
I figured I'd get the pics working for everybody not on TDI Club.
All Credit goes to yetimus.
6 speed ALH TDI
Old 05-08-2009, 07:20 PM   #29 (permalink)
6 speed Diesel FTW!
Diesel
Started an installation thread.
Installing MPGino in 2002 Golf TDI
6 speed ALH TDI
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 999 12-14-2011 01:18 PM
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 08:50 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 06:35 PM
My TDI. (intro thread) Deezler Aerodynamics 9 11-28-2008 09:35 PM
One more TDI...with a twist tasdrouille Introductions 5 01-22-2008 03:33 PM
