Old 05-08-2009, 06:01 PM   #1 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Installing MPGino in 2002 Golf TDI
Just received a pre-Assembled MPGuino Donated to me by DCB.
I have to Stress that this project would not be happening now without DCB's kindness. I Do plan on donating to him/ the project as soon as the checking account recovers from New 1/2 house A/C time.
Only thing accomplished so far is soldering the LCD to the unit.
More to come hopefully tonight.
Any + All information regarding the TDI's VSS + Fuel consumption is highly appreciated.
Threads which will contribute to this project.
#1) mpguino TDI feasability
2)MPGuino for Audi
3)MPGuino - $40 FE gauge - TDIClub Forums
Very Excited.
6 speed ALH TDI
Old 05-08-2009, 06:29 PM   #2 (permalink)
6 speed Diesel FTW!
Diesel
Few Pics to get you guys excited
A Few Pics
The Surprise Package
Well Packed (but bad pic)
Un-Packed
My Poor Solder Job
6 speed ALH TDI
Old 05-08-2009, 08:38 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Sweet, glad it survived. Yellow wire ground, black wire next to red, 12 volts. Car battery in driveway. Couldn't test it without the LCD, hope it boots
note: do try to be deliberate with the power hookup, occasionally these AVR chips mess themselves on flaky power connections.
Old 05-08-2009, 09:54 PM   #4 (permalink)
6 speed Diesel FTW!
Diesel
Excuse my ignorance; does the +12 volt need to be switched, or always on? I Seem to remember that SVO had his wrong for a while; but I can't remember which way it goes.
Either way I'll wire it up with the main fuse out, charge all of the caps through a test light, then replace the fuse; or should I just hit it with 12 volts right off the bat?
6 speed ALH TDI
Old 05-08-2009, 10:11 PM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
The trips reside in ram so you want constant power (not switched). You can just firmly hold the power leads to the battery for an initial test.
Old 05-08-2009, 10:24 PM   #6 (permalink)
6 speed Diesel FTW!
Diesel
As far as my untrained eyes can see; all is well with the unit!
6 speed ALH TDI
Old 05-08-2009, 10:47 PM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
Thank you for that, was not sure. In the setup screen (tap left and right together) on the newer ones (>=.81) there is an "InjTrg 0-Dn 1-Up" option that should be able to invert the signal, you want to use 1 for the audi/vw fuel consumption signal.
I also think yours might uniquely say it has a "Metric" option. It doesn't really, It just escaped in the middle of some testing.
Old 05-09-2009, 03:44 PM   #8 (permalink)
6 speed Diesel FTW!
Diesel
Quick question; If I only hok up fuel signal; what will happen?
Will gph work?
Just trying to test.
6 speed ALH TDI
Old 05-09-2009, 04:22 PM   #9 (permalink)
dcb
needs more cowbell
dcb's Avatar
That's correct, you should get an indication in gph. It may not be accurate until you get it calibrated but it should be proportional if you get the injector slope "InjTrg" setting right. Even without the vss/distance it is still very useable information there, especially for a fixed length commute (or for finding the best route).
Old 05-09-2009, 05:12 PM   #10 (permalink)
6 speed Diesel FTW!
Diesel
Originally Posted by dcb View Post
That's correct, you should get an indication in gph. It may not be accurate until you get it .
Awesome; just needed that to test.
Looks Like Pin 66 on the 80 pin connector does the N146 (quantity adjustment) trick. It's a Brown and red wire; now off 2 find it.
Also working up a How 2 at the moment.
6 speed ALH TDI
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 07:50 AM
