Old 07-09-2013, 09:29 PM   #1 (permalink)
My dad's 2008 F-150
So, my dad tried to help out a friend, and my dad estimated that it cost him a total of $100,000, including this truck, which he bought a few years old, and the friend drove a hundred thousand miles instead of completing projects for my father, then got a DUI, so Dad took it back, and I am using it, at least for the summer. Yay, 14/19!
Front:
Side:
Rear:
I have not driven it much, I just hosed out the back seat and floor, then gave them a good scrubbing. It was very muddy. This morning I unscrewed the back of the tailgate to see if I could get it to work. The friend must have dropped something heavy on it because it was a little flattened, with the front and back bulging, and the tailgate would not open. A friend recommended putting a 2x4 between the tailgate and my hammer, but it seemed ineffective. I have a small hammer and the wood might have been too thick. I used a rubber mallet, which worked great in the back, but left the front looking much worse. However, it works!
I need to take this to a bodyshop
I should have gone there first
I just was not sure this would work
It figures that the handle would break:
So, I need to get estimates from body shops for flattening out the metal. I offered to try to fix it and my dad said that he wanted someone working on it who knew what they were doing. The dealership wanted $1,600 to replace the tailgate and paint the rest to match.
I guess that either the friend or my dad broke the handle, trying to open the tailgate. If I am not mistaken, a new one costs $30.97. This is it, right? 2008 Ford F-150 Tailgate Handle | FordParts.com
It is weird because I love how much leg room I have, but otherwise, I hate how large and unwieldy the truck is. The wheels do not look too bad, I just need to check the pressure. I used my bike pump, but some of the tires did not seem to go higher than 40 PSI, while two were at sixty.
Sidewall maximum is 60 PSI.
The forties were on opposite corners, as were the sixties.
The cigarette\charger outlet does not work, nor does the OBD-II connector, so I cannot use my Ultragauge, and things would be complicated if I had a CEL. I have lawn edging that I bought for Bacon. Do you think that I could attach it with: 3M VHB Heavy Duty Mounting Tape 5952 Black, 3/4 in x 15 yd 45 mil: Amazon.com: Industrial & Scientific
I would love to make an aerocap for this. However, I just do not know for how long I will be driving the truck, although my dad will have it indefinitely--he owes way more than it is worth!
I have actually thought about selling Bacon and giving Dad the money to help pay off the truck.
The other problem with an aerocap is that I really do not want to reduce visibility!
ID:	13425   Click image for larger version
ID:	13426   Click image for larger version
ID:	13427   Click image for larger version
ID:	13428   Click image for larger version
Old 07-09-2013, 09:39 PM   #2 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
Check your fuses
The cig outlet has a fuse either in the cab or possibly under the hood
The OBD-II may be the same way
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 07-10-2013, 06:37 PM   #3 (permalink)
Originally Posted by Gealii View Post
Check your fuses
It is the same fuse, hidden in front of the passenger's door. I needed to go to three stores to find it and it blew right away.
What could be causing that?
Also, I ordered new tires, at least one is bald.
Ouch.
Old 07-10-2013, 06:56 PM   #4 (permalink)
The Dirty330 Modder
Gealii's Avatar
Ouch.
try jumping the fuse up 1 size
Ex. if its a 5A go to 10A
there may be a short somewhere in the system or it just might be the wrong fuse size, it shouldnt hurt going up 1 size cuz when i put in my aftermarket radio i had to up the size or it would keep blowing
- Henry Ford
Old 07-11-2013, 01:53 AM   #5 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
first thing i'd do is find a factory service manual you can d/l(perferably for free); then try to figure out what is on that circuit
Old 07-11-2013, 02:35 AM   #6 (permalink)
I would look for the problem in the circuit. I would not upsize the fuse.
Old 07-12-2013, 09:09 PM   #7 (permalink)
Exceptional Member
YukonCornelius's Avatar
Crapolier - '98 Chevrolet Cavalier base
90 day: 34.81 mpg (US)
05 CTS-V - '05 cadillac cts-v
90 day: 33.01 mpg (US)
95 Accord - '95 Honda Accord
90 day: 38.06 mpg (US)
11 CTS-V - '11 Cadillac CTS-V
I would sell it and buy something else. I doubt that POS kept up with maintenance on it.
Don't know why it says 00, it's a 95
374,000 miles and tired.
