Old 11-06-2008, 11:56 AM   #1 (permalink)
Tracy - '00 corsa
no vacuum for vacuum gauge?
hi
i tryed to install a vacuum gauge at the weekend but it didn't seem to work.
i located what i thought was a vacuum line using my haynes manual. manual said it was vacuum for fuel pressure regulator. the hoze was a small diameter and had no liquids in it when i poped it off. however the needle on the gauge didn't move and i know the gauge works from sucking on it.
using process of elimination this hoze looked like the most likely candidate. maybe my car has no vacuum ? is this possible? i am getting ok mpg though
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 11-06-2008, 07:08 PM   #2 (permalink)
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
Only when the engine is turned off.
You need a vacuum source coming from a simple (no diaphragm or accumulator) fitting on the intake manifold.
If there is no such fitting, examine the intake manifold for a plugged threaded hole. In which case remove the plug and screw in a suitable fitting purchased from you local auto parts store.
HTH
Old 11-07-2008, 07:40 PM   #3 (permalink)
1988 Ford Escort Pony - '88 Escort Pony
90 day: 39.88 mpg (US)
1997 Ford Escort Station Wagon - '97 Escort LX Station Wagon
90 day: 39.4 mpg (US)
Lil Red - '88 Escort GL
90 day: 32.23 mpg (US)
I t'd into the hose going to the vacuum booster for the power brakes. If you use this source be sure you clamp all the hoses tight so you don't have one come off and lose vacuum to the brake booster.
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 07:04 PM
Econometer/Vacuum Gauge Installation Guide Johnny Mullet Instrumentation 76 07-29-2010 08:52 PM
Vacuum gauge DifferentPointofView Instrumentation 18 10-24-2008 03:31 PM
Driving with a vacuum gauge Meph EcoModding Central 13 08-27-2008 09:40 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
