11-07-2008, 04:35 PM
#261 (permalink)
MechE
Originally Posted by Magister
For OBD logging to a laptop, you'll have to enable the serial port and in the get_pid() function you'll have to do a serialWrite() with the info you want to export.
Excellent, just as simple as I was hoping
The transistor is used to drive the brightness as some LCD LED can take 100mA and the pins only output 20mA so if you plug the pin directly on the LCD, you will burn the pin output.
Thanks, I'm sure I have a suitable transistor somewhere
Challenge me, or correct me, but don't ask me to die quietly.
11-07-2008, 10:15 PM
#262 (permalink)
MechE
I've got one more question before I solder my final bits
I'm using a thumbduino, so the power source is the 5V USB host... I don't have a 9V supply... Can I run from a regulated 12V supply? Already, I'm going to power the LCD from an external 5V regulator, I'm not sure if the USB host will support the thumbduino and the LCD (I don't think it will negotiate for more than 100mA).
That 9V is connected to both the 33920 and the OBD2 interface, so I don't want to screw that up
11-07-2008, 11:44 PM
#263 (permalink)
Scoob - '05 Impreza Outback Sport SE 90 day: 25.28 mpg (US)
That pink line coming from Pin 9 on the DB-9 OBD input and going to the 33920 VBB and the Arduino 9V pin is the 12V line from the car. I don't know what a thumbduino is (maybe a stickduino?), but if you don't have a regulator onboard like the Arduino, that pin on the arduino is the unregulated 12V input going to the 7905 reg. That same 12V presumably is a direct input to the 33290, but I'm still need to look up that part's specs to be sure I hook it all up right, so someone correct me if I'm wrong.
11-08-2008, 12:55 AM
#264 (permalink)
MechE
doh! Stickduino  That's not the first time I've made that mistake :X
So yes, after staring at it long enough, it hit me that the arduino needs power
I've gotta debug my setup, it's quite messy - and, buggy
It won't always initialize - and when it does, only one character row (bottom) is showing up, and it's displaying repetitive garbage - looks like the duino is resetting. I don't have it hooked up to the obd port just yet.
When it fails to initialize, the hd44780 chip gets hot. Which also happens if I remove my external 12V supply (arduino still powered on over laptop) - BUT, when I do so, I get random pixel flashes on both rows of the LCD o.0
It's late, but I'm thinking it doesn't like having two grounds - 1 being the PC ground to run the arduino and the other being the 12V battery ground. In fact, I'm not entirely sure how I'm getting anything to display - if the three grounds on the LCD are reference voltages, the digital pins from the arduino don't have a "nice" current loop....
Walking away now - I'll save round 2 for tomorrow...
11-08-2008, 11:34 AM
#265 (permalink)
MechE
Fixed - it was just as I suspected too.
Thou shalt make simple ground loops
It wasn't resetting, the indicator LED on the arduino blinks when it tries to init and when it fails.
Todo
*find a pnp transistor
*move the stickduino power "jumper" Or, make a power USB cable
* wire up the 33290 chip
* wire up an RJ45 socket
* button time
Does anyone know if the 33920 chip absolutely needs the ECU voltage on pin 1? Or if something around 12V will be fine? I can't seem to figure it out from the spec sheet...
11-08-2008, 05:37 PM
#266 (permalink)
MechE
For the interested, SG2 cable pinout
Code:
SG RJ45 OBD Connector
1----------- 4 Signal Ground
1------------5 Chasis Ground
2------------6 CAN High (J-2284)
3-----------14 CAN Low (J-2284)
4------------2 J1850 Bus+
5-----------10 J1850 Bus-
6------------7 ISO K Line (9141-2)
7-----------15 ISO L Line (9141-2)
8-----------16 Battery +
Still working out kinks... I can't seem to get it to initialize. Is the software tested for the 33290 chip? I'm just starting to go over the code now
11-09-2008, 06:19 PM
#267 (permalink)
OBDuino coder
I was never able to test the ISO code as my car does not support it. AFAIK the code should work, if it initializes properly.
Schematic use the standars OBDII-DB9 cable so be careful to have the correct pinout too.
11-09-2008, 06:40 PM
#268 (permalink)
MechE
Thanks Magister
I'm going to dig through older posts and look for standard on how to initialize, and make sure that's actually happening.
I read voltage changes on the tx/rx pins, so I'm going to assume my 33290 chip is working.
I've triple checked my double checked cable pinout... I guess I'll check again  The only "interesting" thing about the cable is that the chasis ground and signal ground are common for the SG cable.
11-11-2008, 11:48 PM
#269 (permalink)
MechE
So I'm going over the code....
prj.perquin.com shows the slowinit sequence as:
Code:
_________ S ___ 2 3 ___ 6 7 ___ ____ ____
\_/0 1\___/4 5\___/P \/\/\/\/ \/\/\/\/
300ms 200 400 400 400 400 250 packet response
1) Wait for 300ms with K line high.
2) send a byte 33 hex at 5 baud. 200ms per bit
startbit: 200ms low
databit0,1: 400ms high
databit2,3: 400ms low
databit4,5: 400ms high
databit6,7: 400ms low
stopbit+pause: 250ms high
4) init serial connection to 10400 baud, 8N1, 1=0Volt 0=12Volt, least significant bit first
5) send package c1 33 f1 81 66 33=dest, f1=our tester id, 81=start comms
6) wait for response 83 f1 01 c1 e9 8f ae 01=physical address, c1=response ok (7f=fail), e9=kb1, 8f=kb2
So everything in the obduino code seems good up until step 4/5.
The opengauge code does the 300ms thing, the 5 baud 0x33 stuff... But then it deviates significantly... Rather than sending data, it waits 60ms and then listens for a response. I don't fully understand what steps 4, 5 and 6 are/do, however.
It's also slightly different on the stopbit, it pulls K high for 200ms rather than 250. But, even with that change, I'm still no go.
Does anyone have a better source of documentation for the proper init sequences?
Referenced openguage function
Code:
/* ISO 9141 init */
byte iso_init()
byte b;
// drive K line high for 300ms
digitalWrite(K_OUT, HIGH);
delay(300);
// send 0x33 at 5 bauds
// start bit
digitalWrite(K_OUT, LOW);
delay(200);
// data
b=0x33;
for (byte mask = 0x01; mask; mask <<= 1)
if (b & mask) // choose bit
digitalWrite(K_OUT, HIGH); // send 1
else
digitalWrite(K_OUT, LOW); // send 0
delay(200);
// stop bit
delay(200);
// pause between 60 ms and 300ms (from protocol spec)
delay(60);
// switch now to 10400 bauds
// wait for 0x55 from the ECU
b=iso_read_byte();
if(b!=0x55)
return -1;
delay(5);
// wait for 0x08 0x08
b=iso_read_byte();
if(b!=0x08)
return -1;
delay(20);
b=iso_read_byte();
if(b!=0x08)
return -1;
delay(25);
// sent 0xF7 (which is ~0x08)
iso_write_byte(0xF7);
delay(25);
// ECU answer by 0xCC
b=iso_read_byte();
if(b!=0xCC)
return -1;
// init OK!
return 0;
11-12-2008, 08:57 AM
#270 (permalink)
OBDuino coder
Step 5/6 is for KWP 2000 (ISO 14230-4), I put only ISO 9141-2 in the code
