Old 08-13-2009, 01:47 PM   #1 (permalink)
OBDuino coder
Magister's Avatar
Titine - '07 Elantra GL
OBDuino CAN version only, progress!
(I have been busy earlier this year so there was delay for my OBDuino project)
I am working on a PCB, I already made a prototype but I am reworking it to be less than 5cm height so it will fit easily in a 1 DIN unit.
There is some pictures here
OBDuino Hardware
Note that this is a CAN version only. While I was working on it, I am happy to see some people enhanced the ISO version a lot!
Magister aka Frédéric.
The Following User Says Thank You to Magister For This Useful Post:
SVOboy (08-13-2009)
Old 08-13-2009, 04:49 PM   #2 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Civic LX
90 day: 40.53 mpg (US)
Keep it up! Do you have a ballpark of how much a kit of it might cost?
Old 08-13-2009, 07:41 PM   #3 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...I, too, am interested in a "kit" project...a "D.I.Y." SGII™
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 08-14-2009, 10:05 AM   #4 (permalink)
OBDuino coder
Magister's Avatar
I don't know for the price right now, MPGuino is $55, OBDuino will be a little bit more because there's more electronics components, PCB is bigger, and only the OBD2 cable is at least $10 more too... There is also much more functionnalities.
Old 08-15-2009, 10:41 AM   #5 (permalink)
The PCB is looking good!
Is there a possibility in the furture for an ISO/ELM version of the PCB?
Old 10-13-2009, 03:20 PM   #6 (permalink)
There is a way how to put more info on single screen at still reasonable budget,
including custom ASCII art, larger fonts, etc. Perhaps might be worth to investigate
compatibility with your production board before release..
This is the TV-output (PAL/NTSC) shield called TellyMate
for Arduino, which could run various mini screens/LCD panels, many code samples here:
Batsocks - TellyMate Shield
Batsocks - TellyMate Shield - Examples
Now incl. new firmware for larger/custom fonts&graphics:
Batsocks - You could get by without us
as seen on this thread discussing Arduino Mega and ARM9
platforms for port of the OBDuino code:
OBDuino Mega
Old 11-23-2009, 11:21 AM   #7 (permalink)
Have you guys seen this OBD to USB converter?
DealExtreme: $29.99 ELM327 USB Vehicle OBD-2 Scanner Tool
It uses a clone of the ELM327 chip and is only $30.
From what I understand it has a RS-232 to USB converter chip onboard so you should be able to pull the data off as RS-232 with a little hacking.
Considering that it already has the OBD connector, dc/dc converters, etc. It might be a little cheaper than building those parts from scratch.
Of course one could always just hook it up to a Netbook, Palm Pilot or Pocket PC and use it as is.
Old 11-23-2009, 11:29 AM   #8 (permalink)
OBDuino coder
Magister's Avatar
I do not trust any of these chinese clone, and you can find them way cheaper on eBay I think.
I would trust something like this:
Serial AllPro Adapter
Old 11-29-2009, 08:01 PM   #9 (permalink)
Hi frederic, are you planning on releasing the source code and schematic for the CAN only version? if so, i would love to beta test it. I have most of the components already (sampled from microchip) and would be able to make a board from the eagle files. I also have a 2008 Jeep wrangler (so CAN only) i would love to test it on.
Old 11-30-2009, 10:27 AM   #10 (permalink)
OBDuino coder
Magister's Avatar
For the moment the code is closed, i put a lot of effort in it, I will do some beta test in Montréal soon however with a few prototype units. I will try to try it on a wrangler, I tried on a 08 Patriot without success and I have no clue why :/
OBDuino Feature Request... electromike OpenGauge / MPGuino FE computer 13 07-23-2009 03:46 PM
Canadians make 4-wheel version of teardrop Dymaxion car in 1938 MetroMPG Aerodynamics 7 04-14-2009 12:36 AM
OBDuino and the 328p? gone22 OpenGauge / MPGuino FE computer 0 04-12-2009 10:56 PM
News: Toyota unveils production version of Smart car competitor MetroMPG General Efficiency Discussion 8 09-06-2008 01:58 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 01:21 AM
