Old 06-14-2009, 04:21 PM   #1 (permalink)
OBDuino mod - no need of 'uino'
Hello,
last week, I found this great "OBDuiono" project on web and I modified the OBDuino32K, because I don't have any arduino hardware.
Now it runs on a Atmega644. I optimized it for (european) C1/Aygo cars (just ISO9141). I had to change some timings and optimized the requests a little: speed/rpm/throttle/intake temperature and map (C1/Aygo don't have a maf) is just requested one time per cycle. But there were many expedient changes in the newest svn-checkout release of obduino32K, so RPM is requested two times again, because ob verifyECUAlive().
I want to use a larger lcd, so I try out a 4x27 Display. Therefore I use 8 corner. But I'll recode the design soon, because it doesn't look good: You can't see the meaning of some values (e.g. "26%").
BTW: The values are not real (just from a "simulated ECU")
You can get my modification here, if you are interessted. It can be compiled by avr-gcc (std=gnu99). You don't need C++ anymore
Thanks to the developer of OBDuino,
Dominik from germany (pleasy excuse my horrible english)
Old 06-14-2009, 04:45 PM   #2 (permalink)
Moderator
Daox's Paseo - '97 Paseo
90 day: 67.16 mpg (US)
Daox's Prius - '04 Prius
90 day: 52.66 mpg (US)
Looks pretty nice. Have you tried it in the car yet?
EcoRenovator.org - Efficient living and green home improvement
Prius Build Thread
Paseo Build Thread
Old 06-15-2009, 10:29 AM   #3 (permalink)
To see a display of the names of the PID's (to check what 27% is of what) just press both the left and right buttons at the same time. This will bring up the names for 3/4 of a second.
There are up to 7 PIDs that are used in calculations on every time through the loop. When a user selects them, they are retrieved again just for display. Yes, not optimal at all... but simple.
Old 06-15-2009, 12:57 PM   #4 (permalink)
Interesting! Your bigger display and Atmega644 remind me about these german projects (full documentation and videos inside):
-> S65-Shield for Arduino (display is taken from S65 - popular GSM phone by Siemens)
S65-Shield - watterott.net
-> ATM based web radio with "big" display
AVR WebRadio - watterott.net
PS if possible pls. share more details about your board
Old 06-19-2009, 11:41 AM   #5 (permalink)
This week I got some MC33290. I was scared to try it with a simple transistor level converter in car, because I don't want to damage my ECU.
Today I tried it in my car with MC33290 and it works fine!
@Mesuge: Thanks for that hint! Now I ordered such a display (a Sharp LS020..). I found this information/libs to drive it (without arduino):
Display Programming . Maybe I will experiment with that in future. But for a car gauge it's to small.
Testing the IAT mod tasdrouille General Efficiency Discussion 6 09-27-2009 05:09 PM
OBDuino and the 328p? bigmoe88 OpenGauge / MPGuino FE computer 0 04-12-2009 10:56 PM
why is gearbox oil mod listed as large improvement in the 65+ mods modmonster EcoModding Central 16 02-10-2009 02:47 PM
Front-end aero mod cephraim Aerodynamics 16 08-17-2008 08:29 PM
Quick and easy licence plate aerodynamic mod :D blackjackel Aerodynamics 7 05-13-2008 08:20 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
