Old 03-07-2012, 02:00 PM   #681 (permalink)
PaulH
MPaulHolmes's Avatar
The power board, low side driver board, and high side driver board are done being routed and are ready to go in. The control board schematic is finished, and the components are being placed. It has lots of safety built in. It's truly a miracle if the 6 pwms actually get through. haha. You power the control board with anything more than around 8v, and then there are 6 isolated homemade (super cheap) DC-DC converters that change the 8v to 18v input to 24v. Then the 24v is divided up to drive -8v to 15v or something like that. If micro is unresponsive for more than 1 ms, adjustable undervoltage trip (too negative), adjustable overcurrent trip (too positive), +12v too low, +25v too low, +5v too low, then the fault pin is set in the dsPIC which disables all pwms, and also the hardware shuts off the power to all the optocouplers independent of the dsPIC.
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
okie00 (03-10-2012), TadhBijou (04-06-2012)
Old 03-07-2012, 04:23 PM   #682 (permalink)
OMG... It's SkeeterB!!!
Send a message via AIM to skeeterb Send a message via Yahoo to skeeterb
Wow! It looks like you really have a bunch of different safety features on there. How would you reset it if the controller shut down because of an over or undervolt situation?
This is the way the world ends,
Not with a Bang
But with a Belch
BUUUUUUURRRRRRRRRRPPPPPPPP
Old 03-07-2012, 06:02 PM   #683 (permalink)
PaulH
Oh, it just tells the microcontroller about it, and then the micro can clear the overcurrent if it feels like it, but the undercurrent won't be cleared until it's no longer an undercurrent state. When that happens, the drivers are automatically re-enabled.
EDIT:
But the UNDERVOLTAGE won't be cleared until it's no longer an UNDERVOLTAGE state. dang it. haha.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
skeeterb (03-07-2012)
Old 03-07-2012, 06:30 PM   #684 (permalink)
Paul, how close are you to having a functional system that we can purchase?
RJ
Old 03-24-2012, 01:38 PM   #685 (permalink)
So I was wondering, can you turn a cheap generator into an AC motor? I mean, not just make turn but, make it efficient and powerful to run a car.
I found this 10Kw AC generator and it seems to me that maybe it could work. Let me know what you think. Thanks.
Look for this and it will come up on the net:
10,000 Watts Max/7200 Watts Rated Belt-Driven Generator Head
P.S. I have the link but it doesn't allow me to post it yet, so I'm going to try a different system by leaving spaces on the alert triggers.
www harborfreight com /10000-watts-max-7200-watts-rated-belt-driven-generator-head-45416.html]Generator Head - 10,000 Watts Max, Belt Driven[/url]
Old 03-29-2012, 12:17 AM   #686 (permalink)
I just read this... I like those words "Less than $100." I'm ready, willing and able to pay the regular fee!
Old 04-06-2012, 05:01 AM   #687 (permalink)
TadhBijou's Avatar
Is something went wrong?
Hi, Paul.
Long time no news. Is everything O.K.?
How are the things going?
Old 04-06-2012, 07:42 AM   #688 (permalink)
PaulH
The boards will be here around the 16th of this month. Hurray!
kits and boards
gtx90 (04-13-2012), TadhBijou (04-07-2012)
Old 04-06-2012, 07:27 PM   #689 (permalink)
YEEHHAA!!!!!
The Following 2 Users Say Thank You to rayjay For This Useful Post:
gtx90 (04-13-2012), MPaulHolmes (04-06-2012)
Old 04-09-2012, 03:27 PM   #690 (permalink)
Liquid Cooling?
Paul,
How hard would it be for me to build one of these with liquid cooling? Or is it already? Aren't there comercially available liquid heat sinks that could be swapped in?
Thanks, and keep up the good work!
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 01:59 PM
