Old 10-06-2009, 12:37 AM   #2381 (permalink)
49state 4door - '91 Metro 4 door
90 day: 59.31 mpg (US)
old blue - '91 Metro base CA
Paul, I made one shunt today. The manganin was almost 1 1/4 inches wide by .060, so I made two sets of taps, one at 0.1 milliohm and one a bit short of .2.The current tabs are just the extension of the manganin strap,
If this and an instrumentation amplifier replace the noisy Hall device, some serious reduction of the resistance between the measuring leg and the current connections will be needed. I roughly calculated the total dissipation of this one at 1000 amps to be 500 watts. Over 100 watts at 500 A. Only the area between the sense leads needs to be manganin, so I figured to silver solder copper pieces on each end for the current connections if it is to be a operating component of the controller. This one was planned to give Paul a way to look at battery current in testing. Give feedback; I can do more. Vista Metals was generous and I have the oxyacetylene torch, silver solder, and copper.
bob
Old 10-06-2009, 01:13 AM   #2382 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
Thank you Bob! This is going to be perfect! I can view the voltage drop across my volt meter set on the 200mV setting. It is going to be so nice to actually see the real life actual bonafide current!
signature goes here.
Old 10-06-2009, 03:38 AM   #2383 (permalink)
PaulH
Aluminum doesn't shield from magnetic fields. Maybe the aluminum case isn't stopping the RF interference? I don't know! This is sort of hilarious.
Here's what I don't get. EMI is electro-magnetic interference. Once it's flying through the air, what does the aluminum enclosure block? Can it block only the electrical part? That doesn't make any sense to me at all. electricity and magnitism are 2 aspects of the same phenomenon. How do you stop it?! Maybe the enclosure needs to be steel? I have no idea what I'm talking about!
Old 10-06-2009, 11:21 AM   #2384 (permalink)
PaulH
Ben, don't worry about changing the resistor values. I don't think that's it. Your controller looked fine on the oscilloscope before mailing it out. There are several of us working on this problem right as I type! ya!
Old 10-06-2009, 01:02 PM   #2385 (permalink)
jackbauer's Avatar
The following takes place between 4pm and 5pm:
We now have an avr programmer!
Now i just need to learn c......................CHLOE! DAMMIT! WHERE ARE YOU?
Old 10-06-2009, 07:18 PM   #2386 (permalink)
Joe
Originally Posted by bennelson View Post
Has anyone else run into getting RF noise from their open source controller on the FM band of their radio?
My radio has a "feature" of auto-tuning to the next station if the station you are on doesn't come in anymore. Tonight, I accelerated enough that the radio automatically changed stations on me!
Is there someway to keep static off my radio?
Do I have to wrap tin-foil around my controller? Time to build a Faraday Cage?
Nope, Haven't had any problems with FM radio, though our signals are pretty strong in the valley. Maybe some other part of the traction setup is the cause? Like, maybe running the motor cables as close together so the high currents in opposite directions will cancel most of the noise they emit. Were there problems before? or only with this controller?
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
Old 10-06-2009, 08:16 PM   #2387 (permalink)
PaulH
Fran got the bootloader working, and fixed a bunch of bugs, and added safety features, and all sorts of awesome stuff to the code! He worked on it until 1:15am Croatia time and just emailed it all to me! That man needs to get some sleep!!!!
Old 10-06-2009, 08:48 PM   #2388 (permalink)
Shields and grounds present some major issues; Morrison's Shielding and Grounding is a standard reference, but I can't find my copy. Must clean up the library!
The main impetus for the shunt project was getting you a way to look at the battery and motor waveforms. Ringing on these waveforms is most of your EMI. First get the source minimized, then shield the sensitive stuff from it.
Old 10-07-2009, 10:20 AM   #2389 (permalink)
Tall Lurker
Here's an interesting page on shunt details from DIY Electric Car
Fieldlines.com || Make your electricity from scratch!
Old 10-07-2009, 10:24 AM   #2390 (permalink)
Tall Lurker
correction: The site is Fieldlines, I found the link on DIY Electric Car
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 671 Yesterday 06:57 AM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 527 09-02-2011 03:35 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
