Old 05-05-2017, 11:24 PM   #7161 (permalink)
ChargE - '92 Mazda MX6 LX
90 day: 33.89 mpg (US)
WinterTransport - '07 hyundai Sante Fe SE
Originally Posted by duncan2 View Post
I'm direct drive to the diff so I am going to use the old ABS sensors on each wheel as my data for the traction control and also the speed/rpm limiter
Sounds like a good plan.
I was thinking about adding the two rear wheel speeds together and comparing to the sum of the two front wheels
I was thinking of a separate module interfacing with the throttle input on the main controller
So it would drop down the throttle input when the tires start to spin - as opposed to just now when the first thing I know is that the tires scream and the back overtakes the front
I would think that Left + right / 2 / rear-end gear ratio should give you motor rpm.
A separate module sounds like a good plan. ABS modules are a part of all of the cars that I know about ... precious little that I do actually KNOW ..
Others have posted silly little messages to get to the fifth post, where you can begin to include links
Is this the link you wanted to post?
Duncan's Dubious Device - DIY Electric Car Forums
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
The Following User Says Thank You to thingstodo For This Useful Post:
duncan2 (05-05-2017)
Old 05-05-2017, 11:34 PM   #7162 (permalink)
Yep that's my thread!
The Device is great fun
I suppose this is number post three - only two to go!
I'm happy about mechanical stuff - I need to learn the electronic stuff
Old 05-05-2017, 11:38 PM   #7163 (permalink)
Post Four
I need to decide what speed I actually need
The road speed limit here is 100Kph
The grass events I have been doing are relatively low speed and even the tarmac ones have a limitation on the allowable length of the straights
The only place where I hit my max speeds is at the drags - I hit 140kph at the 1/8th mile
Old 05-05-2017, 11:39 PM   #7164 (permalink)
Do I want to increase my maximum speed so that I can dare try a 1/4 mile drag race?
Or am I best with a speed limiter?
Old 05-05-2017, 11:41 PM   #7165 (permalink)
I'm the opposite, I'm afraid. If it has wires, I can get it to work.
But aligning mechanical stuff ... or getting a bearing pressed on .. purging the air from a clutch ... like magic!
Old 07-11-2017, 07:04 PM   #7166 (permalink)
Is the hardware overcurrent, set by VR1, an actual TRIP/Shutdown, or does it simply cut back the PWM signal?
I'm having an issue with a modified, overpowered, PS board. When I hit full amps, 511 as seen on the RTD explorer, it seems to cut way back on power, even through the PWM still says full voltage?
I was running about 1250 amps (seen as 511) at only 50% PWM, for about one second, then power fell off, PWM showed 100%, but it felt like about 25% power.
Old 07-13-2017, 12:37 AM   #7167 (permalink)
As far as I know, it is a hardware detection circuit that disables the MOSFET driver, and it latches the over-current, and it displays a fault code, and you need to cycle power to get the Cougar to turn on the MOSFETs again.
Since it is hardware it is *FAST* ... the output from the current sensor is compared to a reference voltage with a comparator. When the voltage from the current sensor is above the reference voltage, the output of the comparator changes and the MOSFET driver is disabled.
I believe that there is a latch in there, but the micro may do the latching.
I'm a bit fuzzy on the details.
Paul will have to answer whether, under some weird set of circumstances, the High Current Fault would NOT latch, and if it didn't latch, how fast the circuit would enable after the current falls off (since the MOSFETs are turned off) before the MOSFETs are turned on again.
But this would not be normal operation!
Modified and over-powered? How are you getting rid of the heat? You need a *LOT* of air moving across the heat sinks to get rid of that much heat.
Heat is proportional to the square of the current. I think that's one of the reasons that electric cars use such high voltages - the power electronics are easier to cool. And the copper wires don't need to be as big. And the contactors don't have to be as big
Is it possible that the modifications messed up the latch on the overcurrent somehow?
The PWM does not need to be very high at low revolutions to draw high amps. If the back EMF from the motor is low, lots of current can flow. But I guess that's why you built that DC Monster Controller!
What you describe sounds more like a heat issue to me. As the MOSFETs pump the amps, the temperature sensor gets hot, the PWM is limited to reduce the heat .. that sort of thing. I don't know where in the code (before or after the display section) the PWM is backed off.
*BUT*... there are others on this board who have hands-on experience with the Cougar and will give you a better idea on what to chase.
These are only my opinions, after all. I don't have an operational original Cougar 500A (although I did KILL one)
Old 07-16-2017, 07:07 PM   #7168 (permalink)
Hi Paul
Are you selling the high voltage DC controller? - and where can it be bought from?
With the Soliton going away there are people looking for replacements
Mine is still going great but If there is any more advanced software - especially around the ramp up time I would be interested in updating mine before the spring
Thanks
Duncan
Old 07-22-2017, 08:17 AM   #7169 (permalink)
First off, I apologize for giving such a vague post, when 'thingstodo' posted such an informative and inquisitive reply.
Let me start over.
I have the P&S control board, but instead of the mosfet driver on the board, I run that into dual IGBT drivers. The IGBT drivers drive 6 400A IGBTs. I've derated this to 1200A. Surface mount hall effect sensor, with enough spacers so that the control board sees 511A when the actual motor current is 1200A, roughly. I've got another similar controller running 4x400A IGBTs.
This setup has worked extremely well. About my only issues was some cold solder joints where I was tacking on wires to Paul's beautiful control board.
I've been running this for a few years. This is in a custom pulling tractor. 135V x800A of headway cells. Used to be 170V but I keep losing them. 31x15.5-15 tires. 1900 pound class. 13" series motor chain driven to a ford ranger rearend. Was about 1:1 chain ratio to a 5.13:1 ring/pinion.
About a month ago, I was on a pretty good run, and at the end of the track the rear started clunking. Broke a few teeth off of the pinion gear. I replaced the 5.13:1 setup with a 3.55:1 gear, as thats the quickest/cheapest thing I could find. Changed the sprockets and ended up with a little bit faster final ratio.
Also somehow related, my forward/reverse contactor setup to switch the motor field welded in the forward state. Something must have surged or to weld that contactor AND break the rearend.
Anyways, slapped it back together to compete the next week, and try to stay in the points chase. Tractor took off then then falls flat. I didn't have the computer hooked up, so don't know the details. Did the very same thing the next day. So during the week I took out the forward/reverse contactors. Thought that may have been causing problems or a severe power loss.
Next event, same thing. Next day, finally hooked up the laptop to get a datalog. This time I observed full 511A motor current, but I've limited it to 300A battery current. So the PWM was only like 50%. Then after around one second, the PWM went to 100%, and current bounced around, as observed on the datalog. But in reality, the power just fell flat.
Now know that 511A motor current is actually like 1250. Previously, over the years, I had only seen about 1100A max.
Well, open opening up the controller this morning, I found the VR1 pot was set all the way CCW. So seems like hardware overcurrent protection would come into play if I'm pushing it all the way to 511A, although it may not work exactly like it was originally designed? Power absolutely fell off, and current on the datalog was funny and bouncy.
RECALL that I ended up gearing it a little bit faster than before, so it would logically see more amps than ever before.
So I think I'll turn up the hardware protection, and changing gearing to keep it more inline. That hopefully will do the trick.
Old 07-22-2017, 12:25 PM   #7170 (permalink)
PaulH
MPaulHolmes's Avatar
Hi duncan! Yes I can make changes to the controller code for better launches.
I've since much improved how the PI loop works on the AC controller, and that's directly transferable to the DC controller. I'll make the changes and you can test it out.
bad fish racing: It could be the hardware overcurrent protection. Yes I would twist the pot fully clockwise. What current sensor are you using? How are you doing the current sensing? Is it on just one of the 4 IGBTs?
kits and boards
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3199 04-18-2018 07:47 AM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
