Old 12-02-2011, 10:11 PM   #1 (permalink)
Shorty Small - '90 CRX HF
Possible CRX HF Mod Questions
I've ordered a MPGuino and am waiting to install it before doing any modifications to my CRX. I would like to establish a baseline first. BTW, does anyone know how long it takes to receive the MPGuino?
For now I've been trying different driving styles to see how that alters my MPGs.
Mods I'm Considering:
-Radio Delete, (I don't listen to it)
-EGR Port Cleaning
-Fuel Injectors Sonic Cleaned
-Valve Adjustment
-Increase Tire Pressure
-VX Wheels w/ LRR Tires, (when the time comes)
-Complete Tune-Up
-FI Cut-Off Switch
-Remove Spare Tire + Tools
-SeaFoam Treatment
-Amsoil 0W-30 Motor + Transmission
-Lower Ride Height
Questions:
-Will I see a noticeable difference in fuel economy by lowering the ride height of my CRX?
-Are the Civic VX wheels lighter than the 90 CRX HF wheels?
-What LRR tires do you all like?
The HF:
Thank You,
~Jason
1990 CRX HF
Old 12-02-2011, 10:58 PM   #2 (permalink)
HydroJim's Avatar
the amount of mpg you save versus the cost of lowering is probably not that great, but lowering your car does increase fuel efficiency. For LRR tires, I prefer Bridgestone Ecopia EP422's, because those happen to be the cheapest in my area in my size. I'm sure it varies by region. Goodyear assurance fuel max and michelin energy savers are also good. I don't know about the weight of the wheels but I can guarantee that they are close in weight. I'm sure someone on here knows.
By the way, that is one clean CRX! you've got a great car to work with.
Old 12-03-2011, 12:26 AM   #3 (permalink)
60+ mpg at posted speeds
California98Civic's Avatar
Black and Green - '98 Civic DX Coupe
90 day: 64.83 mpg (US)
Nice little car. I have seen the CRX phone dials described as 18lbs on honda tech. My VX wheels are 9.7lbs. Roughly you might double that number to figure rotational mass. Ride height, I plan to test lowered ride height using $30 clamps (plus an alignment) instead of committing to new coils for 20 times more. Deleting your radio will not make much difference. Don't mar that good-looking dash.
Black and Green will be rebuilt over decades as parts die--until it becomes a different car. Goal is only 60-70 mpg at posted speeds. I'm not trying for highest possible mileage.
Calculators: standard deviation, Ohms Law, & drag HP losses.
Old 12-03-2011, 03:06 AM   #4 (permalink)
The original tires for the 1st-gen Insight (I think Bridgestone RE-90s in one particular size?) seem to have very low RR. Worth a look for those.
-soD
