Old 09-08-2014, 10:55 AM   #51 (permalink)
90 day: 57.73 mpg (US)
air dam
Did a bit of fiddling with the car this weekend...
Deeper air dam:
This is my first ever "classic lawn edging" air dam, and it leaves about 3.5 inches of clearance. I just screwed it on to the original air dam, though it's going to need some extra bracing behind it to stiffen it up.
Original air dam from the factory:
ID:	15775   Click image for larger version
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
Daox (09-08-2014), OG VX (11-30-2014)
Old 09-08-2014, 11:08 AM   #52 (permalink)
A B A testing planned?
Old 09-08-2014, 11:11 AM   #53 (permalink)
A-B. No A-B-A.
Once I've got all the mods done, I'll repeat my original speed vs. MPG runs. So we'll call that a weak A-B comparison.
Old 09-08-2014, 11:25 AM   #54 (permalink)
coro wheel discs
Re-inventing the wheel disc...
I knew better than to try rare earth magnets again, after the 25% failure rate from my last coroplast wheel disc adventure on the Flea. ( http://ecomodder.com/forum/showthrea...aps-28214.html )
For this new experiment (anything to avoid actually buying hubcaps to modify!), I zip tied "blocks" of coroplast tightly to the wheel itself. Screws hold the discs to the blocks. I just need to get some stainless screws so the heads don't rust.
ID:	15777   Click image for larger version
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
mikeyjd (01-14-2015), OG VX (11-30-2014), pletby (09-29-2014)
Old 09-08-2014, 11:32 AM   #55 (permalink)
Remaining mods checklist...
[ x ] - grille blocks: full upper & partial lower
[ x ] - passenger outside mirror delete/downsize
[ _ ] add small convex mirror to trailing edge of driver's outside mirror (so it can be folded back on the highway & still be usable)
[ x ] - rear decklid spoiler (copy hybrid style)
[ x ] - engine kill switch
[ x ] - DRL switch
Update: completed mods marked with 'x'
Old 09-08-2014, 11:35 AM   #56 (permalink)
Originally Posted by dirtydave View Post
My KIA has the same size engine about the same weight and about the same high RPMS I cant wait to see what kind of numbers you can get!
I think it's going to be in the neighbourhood of what you're getting. I'd like to see 50 for the winter... but that may be a tall order in sub-zero temps. Which reminds me, I should check if there's a block heater in this car.
Old 09-08-2014, 02:38 PM   #57 (permalink)
The air dam and wheel covers look great! Those look like perfect circles!
Old 09-10-2014, 12:12 AM   #58 (permalink)
Did the passenger side mirror deletion today. Still need to fasten a much downsized replacement on the door. I need an outside mirror since I often reverse into tight parking spots. It'll be complemented by a bigger interior convex mirror.
Getting closer to doing the "B" portion of the A-B testing...
Old 09-20-2014, 10:48 PM   #59 (permalink)
Got all four wheel discs mounted this afternoon. Will snap a pic tomorrow.
I decided the air dam needs some stiffening/reinforcing. It's a little too floppy, and I suspect it deflects back at highway speeds, though I haven't stuck a camera on to confirm.
Old 09-21-2014, 09:33 PM   #60 (permalink)
wheel discs on, grille block under construction
All four mounted now...
I took the car up to ~110 km/h and double-checked them. All looks good.
Started on the grille blocks as well. I just used some scraps of wood to sandwich the factory grille, and screwed coroplast into the scraps:
Before...
Now:
Upper is now completely blocked. I'm going to reposition the plate to the lower right grille area, leaving a center opening about the size of the plate itself.
ID:	15898   Click image for larger version
ID:	15899   Click image for larger version
