Old 10-28-2010, 02:14 AM   #391 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Grand Voyager SE
why are you talking about carburators? not ONE of my daily drivers has a carburator? do you just latch onto anything that might back your argument and then just white out anything to contradict that?
want my replies to be one or two thoughts? then make YOUR STATEMENTS one or two thoughts :-)
Over and out is a contradiction.
over means I am done and await a reply
out means I am done and signing off no reply expected
The Following User Says Thank You to Nerys For This Useful Post:
Allch Chcar (10-28-2010)
Old 10-28-2010, 08:16 AM   #392 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Well, I think this thread has had more than enough, so I am locking it.
Nerys, you need to get over it. Yes, ethanol will decrease your mileage. Now, you need to live with that mileage, or modify your engine to run better with it. You do realize you can probably modify your engine to run more efficiently on ethanol than gasoline? Even nascar is switching to ethanol blended gasoline, and they're getting more power out of it. Anyway ,this is ecomodder, we modify our cars to get better mileage, so learn about ethanol and do it. Whatever you do, you need to stop complaining about how ethanol is the devil and it should be banned. Its just not gonna happen, and its actually a great fuel once you learn something about it. Yes, the current production method is horrible, but that will be improved through cellulosic ethanol production methods. However, it also lessens our reliance on foreign oil. So, there are pluses and minuses. In any case, ethanol is here to stay and we'll only be using more of it in the future.
The Following 8 Users Say Thank You to Daox For This Useful Post:
Allch Chcar (10-28-2010), cfguy2000 (11-11-2010), Chuck. (11-01-2010), graesack (05-12-2012), Mustang Dave (10-28-2010), rmay635703 (10-28-2010), tiderfish (09-02-2011), UFO (10-28-2010)
I want to get to the bottom of this ethanol killing my mpg Nerys General Efficiency Discussion 172 07-20-2010 01:06 AM
The Ethanol Scam: Are ethanol advocates giving slanted mpg numbers? Ptero Fossil Fuel Free 15 04-22-2010 09:58 AM
The Ethanol Bubble Pops in Iowa hypermiler01 Fossil Fuel Free 13 04-18-2010 02:19 AM
Ethanol blends: 10% in "reg." gasoline, 5% in mid-grade, 0% in premium (in Ontario) MetroMPG General Efficiency Discussion 40 03-26-2010 09:27 AM
Ethanol in gasoline i_am_socket EcoModding Central 83 12-18-2008 09:01 PM
