Old 08-06-2009, 11:01 PM   This thread is in the EcoModder Project Library | #1 (permalink)
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 43.01 mpg (US)
Solar Roof
My coolest mod yet!
More photos and details than you'd ever want on my blog:
Scientific Method meets Fuel Economy: SolarArray
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
The Following 2 Users Say Thank You to gascort For This Useful Post:
dremd (08-14-2009), Piwoslaw (08-02-2010)
Old 08-06-2009, 11:07 PM   #2 (permalink)
Matt Herring's Avatar
Bone's 2010 Prius - '010 Prius Black
90 day: 56.78 mpg (US)
That's nifty...like it! Forgive my ignorance but what are you powering in the car with the energy it generates and will it (or how will it) help FE?
Old 08-06-2009, 11:43 PM   #3 (permalink)
gascort's Avatar
Matt,
It's going to augment my alternatorless-ness. Nothing now - but I have plans for it. Daox, Orange4boy, and I have been working on a solution for low voltage issues.
I have a trickle charger already, but this is fun, cool, and a step toward learning about solar. I don't want to spend $500 on an inverter system until I can get a simple battery system working well.
Old 08-06-2009, 11:52 PM   #4 (permalink)
Thanks for the info. and was interesting reading your build blog too! Great pics and good to hear the wife is on board as well...never hurts to have a little support. Best of luck and will be following your progress!
Old 08-07-2009, 12:31 AM   #5 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
How much does the setup add in weight?
Have you considered also using the hood?
How much do you think the panels you used cost?
Have you considered getting packs of "Damaged" panels from eBay?
"żʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
Old 08-07-2009, 01:38 AM   #6 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
I wonder if the hood is a good idea. First, at certain angles it could cause more glare than the normal hood paint job, blinding the driver. Second, the hood gets warm when after the engine has been operating, and solar cells' efficiency decreases with temperature.
I'm also interested in weight.
Piwoslaw's Peugeot 307sw modding thread
Old 08-07-2009, 03:49 AM   #7 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
gascort -
100 Watts in 4-5 hours of sun. How many daytime alternator-less miles does this translate to?
CarloSW2
American Solar Energy Society
Old 08-07-2009, 05:02 AM   #8 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
Nice roof panel! I like the tree /power lines reflection. Looks like power palm trees. Very post modern metaphor.
For 5 hours charging at 100 watts that's 40 AH theoretical before losses. Not too shabby.
I need one for my Kammback...
Keep on amping!
Old 08-07-2009, 08:19 AM   #9 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
That is really sweet! I love how you have so much area you can use. I'm a bit jealous of that, haha.
Just the other day I was talking to SVOboy about doing something similar. My idea was to use my sunroof and paste the cells to the bottom side of it. This wouldn't nearly the area yours does though.
With you pumping out that many amps, you're probably gonna wanna pick yourself up a charge controller too I'd imagine.
Old 08-07-2009, 10:55 AM   #10 (permalink)
gascort's Avatar
Basically nothing. Each "string" of 14 cells in series weighs less than one pound. I had to keep them from blowing in the wind as I lifted them up and set them in place. The plexiglass is 95+% of the added weight, and it's probably about 20 pounds. It would be about 10 pounds if I wasn't stupid and got the right thickness (the thinnest Lowes sells is much more flexible than what I got)
Yes! I have one string producing 7.25V up there that I can't come up with a use for unless I add more somewhere else later. I was thinking probably the hood, or also a neat idea would be the top 6" of the windshield, where it's tinted dark blue or black anyway. Hood is the flattest, and most ideal, though.
They were $2.50 each. Each was rated at 1.8W
These are those ones from Ebay, and most looked like new. Some had chipped edges, and a couple had cracks. Even the cracked ones work fine.
I got them from ebay seller fred480V, it looks like he sells lots of solar cells from his feedback, and he's got some new ones for sale now that are way more powerful than these. His auctions state something like, "best in the world right now" or "best available on Ebay at this time"
The Following User Says Thank You to gascort For This Useful Post:
johnlvs2run (03-13-2011)
Commercially produced aerodynamic pickup bed cap MetroMPG Aerodynamics 481 04-16-2012 12:31 PM
Replacing alternator with solar panel array on roof? blackjackel EcoModding Central 91 01-19-2012 09:19 PM
xB Solar panel roof trikkonceptz EcoModding Central 10 02-28-2009 03:27 PM
Solar cell panel on the roof..?. Xringer EcoModding Central 5 09-07-2008 01:51 AM
