Old 11-18-2010, 12:01 PM   #11 (permalink)
Originally Posted by rbrowning View Post
I wonder what caused the hump in the curve for the Corolla? Aero? Surely it would have been in top gear before 60.
That top gear is at 43mph, I believe.
Found some more...
Assorted cars, including Yaris and Insight II by Consumer Reports, courtesy of MetroMPG (as with the Auto Bild chart)
Old 11-18-2010, 12:02 PM   #12 (permalink)
I wish it was as simple as speed vs mpg for me. In the Insight, mpg is very noticably affected by things like temperature, winds (even light winds), road surface, & driver mood - yes, I do get better mpg when I'm happy about where I'm going. I haven't figured out the exact phase-of-the-moon vs mpg chart yet, but I'm sure it's there.
Old 11-18-2010, 12:27 PM   #13 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 47.93 mpg (US)
Here's another. My Odyssey, with the same drivetrain, predictably matches these results.
It also shows the bump when it shifts into top gear, like the Corolla above.
from Honda Ridgeline MPG vs speed graph: fuel economy with & without cargo trailer
Old 11-18-2010, 12:29 PM   #14 (permalink)
Steve's Suzuki - '00 Suzuki Swift GA
90 day: 51.99 mpg (US)
About 1233 rpm @ 55 mph- jealous!
You would only get 1233rpm at 55mph if you forget to shift into 6th. Im jealous of the 1500rpm at 110mph! Those are some TALL gears.
36.5 mpg is very impressive for a 7.0 liter. Wow.
Old 11-18-2010, 01:02 PM   #15 (permalink)
Some of those graphs show best mpg at very low speeds like the 2006 Toyota Corolla 1.6L Auto and vette . you think its in high gear at such low speeds or is it somehow getting better mpg not in high gear .
Old 11-18-2010, 01:38 PM   #16 (permalink)
euromodder's Avatar
GasDwarf - '13 Volkswagen up! EcoFuel CNG
I'm not surprised by it (only slightly so by the speed where it happens).
I have a hard time getting decent FE @ 90kph/56mph in 5th (top) gear, and it's the same with anything below 60kph/37mph in 4th.
The (smallish) engine revs low at these speed/gear combinations, barely 1600rpm.
I suspect it simply doesn't have the power to cope with the high loading.
A little bit faster, and it goes straight into its FE sweet spot around 100-105kph/62-65mph
Coming out of a deceleration phase and ending up in these situations, mpg will be OK. But any incline, or any attempt to accelerate will instantly result in a massive drop in mpg.
I've recently started to go back to 4th rather than stay in 5th, to come out of a tunnel on my commute and it seems mpg on the climb is better (or not as bad) in 4th.
I think I'm going to go ahead with an ECU remapping that gives more power and torque at lower revs.
I could use the odd extra 50 Nm around 1400-1600 rpm to bring the rpm down by 200-300 rpm - and drive in a higher gear.
As it is, the car needs a fair bit of throttle to get going smoothly.
HP and torque diagram of the Rica E-power remapping :
GasDwarf's fuel consumption :
Old 11-18-2010, 02:37 PM   #17 (permalink)
right, I would assume somewhere around 40-50 mph would get best mpg as this would be approx speed of high gear . But in that first graph of 2006 Toyota Corolla 1.6L Auto it gets best at 24 mph, no way it is in high and as noted above the next bump is probably the high gear one .
I am just surprised it can get such good mpg, even besting high gear speeds .
If the engine is to small for gearing and weight, I would assume best would just move up on rpm scale, not go down in speed .Yes I realize most small engines peak there TQ at like 4-5k rpm which doesn't help real low rpm cruising .
Old 11-18-2010, 03:16 PM   #18 (permalink)
Tested: speed vs MPG - 2006 Toyota Corolla automatic
MetroMPG talks about that here too. It would be interesting to find out just how many cars out there can achieve their best mpg just below top gear.
Old 11-18-2010, 05:32 PM   #19 (permalink)
That answer a lot of questions , thanks .
Old 11-19-2010, 07:52 PM   #20 (permalink)
90 day: 50.45 mpg (US)
Winter beater Metro - '00 Chevrolet Metro
90 day: 56.78 mpg (US)
Good thread!
Originally Posted by RobertSmalls View Post
We should all include the source of our data, so folks know how good the data is.
Yes, please! Links are also nice. I've added links to some of the posts above.
Also, when Wayne Gerdes reviews a car, he does an mpg vs mph test on it.
That's excellent. Ideally, that kind of info would come with all car reviews. Or at least with reviews about so-called economy cars.
Periodically we get claims of higher fe at higher speeds, or at a certain speed range that isn't near the low end. I suppose it's possible if an engine has a peaky BSFC combined with certain gearing and loading... but most of the time I'm tempted to chalk those claims up to faulty fe calculating.
That's exactly why I wanted to do that Corvette Z06 test: to get some actual data to point to when that tired old line comes up.
Latest mods test: 15 mods = 15% MPG improvement: A-B test, 2007 Honda Civic 1.8L, 5-speed
Ecodriving test:
Manual vs. automatic transmission MPG showdown: Nissan Micra 1.6L
The BSFC chart thread (post 'em if you got 'em) MetroMPG General Efficiency Discussion 292 04-16-2018 03:13 PM
EM Blog: GM engineers feel MPG gauges should be in all cars MetroMPG Instrumentation 2 10-24-2013 04:56 PM
2011 Ford Fiesta SFE (29 city / 40 hwy MPG US) Nels General Efficiency Discussion 68 11-29-2011 11:46 AM
Field Weakening Experiment for Speed Increase TomEV Fossil Fuel Free 12 04-10-2008 03:53 PM
EM Sticker contest #2: guess Mom's MPG! ('97 Camry 4-cyl auto) ends Sun., Feb. 3 MetroMPG Hypermiling / EcoDriver's Ed 33 02-04-2008 09:30 PM
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
