Old 04-23-2012, 06:25 PM   #21 (permalink)
impact
Originally Posted by Vman455 View Post
Thanks for pointing that out! I'm going to take it one step further, and tell me if I'm off base here. What would happen if I ditch the Lexan entirely and leave the rear window and trunk lid uncovered, with the tail coming up the sides to the roof and then everything past the trunklid built up to the template? Essentially, a larger cutout inset in the slope? Is there a maximum size where that will start to impact the airflow?
I kinda did that with the CRX.
*I extended the C-pillars along the 'template' curvature on each side of the hatch.
*At the top,I had a cantilever wing projecting out about a foot along the 'T' curve.
*Then I had a low wing which extended back to intercept the 'T' curve which morphed into the boat tail.
Leaves captured inside the 'void' would dance around,impelled by the vortex,with outer flow glancing off the vortex.
Cd (04-23-2012)
Old 05-08-2012, 05:26 PM   #22 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Before I embark on the tail, I figured it would be good to get some more fiberglass experience since I have very little (I built a sub box once, but that's about it). So, I found some inspiration in this thread and started chopping up my stock mirrors. I basically followed the same process, with the exception of having to glass in the plastic bit that holds the attachment bolts as it's a separate piece from the mirror housing in my car. Bondoed and sanded:
Painted and on the car:
Next up, I'm going to glass and paint the upper grill to match, and then do the lower bumper. Then I think I'll be ready to tackle a full tail.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 5 Users Say Thank You to Vman455 For This Useful Post:
aerohead (05-08-2012), DukeEcoNukem (06-13-2016), mcrews (06-01-2012), NachtRitter (06-02-2012), Regenerit (05-08-2012)
Old 05-27-2012, 06:40 PM   #23 (permalink)
bheadrick's Avatar
Nissan Sentra - '01 Nissan Sentra GXE
90 day: 46.29 mpg (US)
any further progress?
Old 05-28-2012, 10:21 AM   #24 (permalink)
Moderator
Vman455's Avatar
Actually, yes--I pulled the bumper cover and grill off yesterday, removed the galvanized steel flashing, and covered them in expanding foam which I let set overnight. I'm about to cut/sand them down and fiberglass over them, then sand/Bondo and paint. Pics to follow!
Old 06-01-2012, 03:32 PM   #25 (permalink)
Moderator
Vman455's Avatar
And done! After removing the flashing, I filled the grill and lower fascia opening with expanding foam:
Cut off the excess with a kitchen knife:
Then fiberglassed:
After our hottest weekend of the year last week (97--and it's only in the 50s today), I noticed my temperature creeping up when the AC was running. So I made the radiator inlet slightly larger than what I had in the sheet metal:
Sanding:
Lots of sanding:
Painted:
And on the car!
I adhered to the 10-foot rule; it looks pretty good...from 10 feet away. If I have more time in the future I can go back and clean up some spots, but overall I'm happy with it for how much time I put in. And it looks much less conspicuous than the galvanized steel!
The Following 11 Users Say Thank You to Vman455 For This Useful Post:
aerohead (07-02-2012), BamZipPow (01-10-2013), California98Civic (06-01-2012), ChazInMT (06-01-2012), HyperMileQC (01-04-2013), Iexpedite (06-02-2012), JohnS (06-06-2012), mcrews (06-01-2012), OG VX (09-12-2015), Sven7 (07-02-2012), whatmaycome14 (09-12-2015)
Old 06-01-2012, 04:55 PM   #26 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Dang Dog..Really great work!! Great pics too. Thanks a bunch for sharing.
Old 06-01-2012, 06:50 PM   #27 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Excellent.
Old 06-01-2012, 06:58 PM   #28 (permalink)
Sport Compact Driver
Celica Gts - '84 Toyota Celica Gts
Sports Cars
90 day: 26.32 mpg (US)
The Bee - '96 Mazda B4000 4x4 Base
Pickups
90 day: 20.39 mpg (US)
Fantastic job. But why black? Why not make it red like the rest of the body? Just wondering, looks really good.
Old 06-01-2012, 08:59 PM   #29 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
I can answer that..... you never get a perfect match when you try to go factory color.
The black is PERFECT!!!!!!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Sporty Modder (06-01-2012)
Old 06-01-2012, 10:21 PM   #30 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Nice job Vman. How do you see out your side mirrors. Seems like there may be some safety issues. When I had an Illinois drivers license I was required to have outside mirrors. It is a fairly common restriction.
Do you have narrow mirrors in your flattish panels?
Noah Webster, 1787
