Old 05-03-2014, 01:04 PM   #21 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
that would imply that your normal engine groundstrap was insufficient.... i would take a look at it and remedy the issue for redundant grounds.
Old 05-03-2014, 02:47 PM   #22 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Have you tried switching over as many lights as possible to LEDs?
Most of mine are LED. I don't have a problem with lights, but if I go above 2 on the blower motor, my ELD sensor "freaks out" and goes into a surging idle (900-1500 cycle). Not sure if its an issue in the circuit or normal amp draw. Either way seriously considering bypassing the ELD on this circuit since 95% of the time I'm at 1700rpm + (minor loss of voltage at idle is temporary).
Shooting for 600 miles of range at 65-70 mph out of a vx.
Old 05-31-2014, 02:48 AM   #23 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I am about to do the timing belt and have to remove the crank pulley, so I am considering a mod now, while it is easier. In my research, I'm learning that reducing pulley weight is a critical part of any efficiency gains--not just the reduced RPMs to the accessories. So, how about a set up such as this? Consider: lightweight underdrive crank pulley coupled with a lighter and smaller alternator pulley. The net result would be less overall rotational mass, underdriven PS and AC (saving power), but normal RPMs on the alternator (preserving OEM charging specs).
What do you think?
I already deleted PS and AC and I have reduced electrical loads all around the car, so I'm not proposing this set-up for me. Just thinking outloud.
Here is a key article I found that helped me understand what I'm considering:
What You Need Know About Pulleys - Car Craft Magazine
james
Old 05-31-2014, 07:59 AM   #24 (permalink)
On a 1.6 d-series, the crank pulley is dampened. I would be reluctant to change this design since the rod to stroke ratio is worse also. If you want to go this route, change the accessory drive pulleys.
Old 05-31-2014, 08:11 AM   #25 (permalink)
Originally Posted by Goldenstate View Post
The thought of a high efficiency lower RPM alternator with and active rectifier is an interesting ecomodding thought. Where can one find out more on this type of improved square conductor alternator?
This style of alternator seems to be something new on the market and sounds like it might be something of interest to our needs. Perhaps it is one of the many advances in technology one can find in foreign countries but still not for sale in the US.
Denso makes them. The stock 150A alternators on the Sienna are square conductor "hairpin" stator, I think. (might have gotten the amperage, and the model wrong lol)
Active rectification is something you have to custom fit. I looked into Schottky diodes, the leakage is really high and probably would not be good for this application. TBH it shouldn't be that hard to make a primitive one.
Old 06-01-2014, 06:20 PM   #26 (permalink)
Cyborg ECU
I have heard this said a lot, and it makes me pause and think and read more. Searching around for opinions and experience, I found this thread on another forum. This particular post and the whole thread are informative:
are pulleys worth it? - Unofficial Honda FIT Forums
But I can't find an appropriate pulley anyhow. All the racing pulleys are for 1992-1995s or later K-series engines.
Old 06-01-2014, 07:00 PM   #27 (permalink)
Unorthodox makes p/s and alt pulleys for yours.
