Old 08-10-2010, 11:52 AM   #1 (permalink)
Vacuum Gauge plumbing
Hey guys, I've just received my TIM Vacuum Gauge and I'm looking at where to plumb it on my 1998 corsa 1.4 16v automatic.
I found the hose going from my manifold to the MAP (manifold absolute pressure) sensor and this is the perfect tube for tapping into (size and location) but would plumbing my T-peice into here cause any problems with the MAP sensor? and would I get an accurate reading from here?
The only other alternative is the other vacuum pipe which has the EGR valve connected to it, and I'd rather not plumb on there because of the much the EGR kicks around.
Thanks
Old 08-10-2010, 01:28 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Either location would be fine. It won't mess anything up.
BTW, welcome to the site.
Old 08-10-2010, 01:30 PM   #3 (permalink)
Thank you for the welcome! I thought it'd be the best vacuum line to Tee into, but I was unsure, not played with vacuum on the engine before, but everything else I have!
Looking forward to getting some better mileage out of my corsa, its a shame I had to sell my 2.0 HDi peugeot, I could get 62mpg on a good run with that. the corsa cant come close!
Old 08-10-2010, 02:15 PM   #4 (permalink)
insane in the propane
Cloud Car - '96 Stratus ES
90 day: 39.15 mpg (US)
expirement with different areas on the intake manifold to see if any offer a greater reading of vacuum compared to others. this is often the case, praticularely vacuum ports on or near the throttle body typically show lower vaccum. some of them are purposely made that way. my car has one such fitting.
if you do find that some fittings on the intake show greater or lesser vacuum readings, then chose the one which shows the greatest amount of vacuum on the gauge. usually just having the car idling is sifficent to test the different intake manifold vacuum fittings.
96 stratus "es" v6 auto-stick
supplementary propane injection
injector kill switch, alternator kill switch
Charging system voltage increased to 15.5V
secondary and tertiary 12v batteries in the trunk
on-board battery charger
lights converted to led's
potentiometer controlled tps for ign timing
welded straight pipe in place of cat-cons
removed egr
3 inch body drop
90psi fuel rail & -50% low volume injectors
run 15% diesel 85% gas
10-minute Accord vacuum gauge "install" Clev DIY / How-to 7 09-10-2010 03:53 AM
vacuum gauge installed Rainh2o Instrumentation 4 12-08-2009 12:09 PM
Vacuum gauge: all or nothing! elhigh Instrumentation 2 04-23-2009 08:57 PM
Tach & Vacuum Gauge Installed midnight rumbler Success Stories 8 01-01-2009 01:33 PM
no vacuum for vacuum gauge? modmonster Instrumentation 2 11-07-2008 07:40 PM
