Old 02-10-2010, 06:44 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Very easy grill block
Hello,
In my first post I propose a very easy grill block made with a clear acrylic sheet you can cut with scissors and tie with 'cable tie plastic'.
In summer with 25-30ºC, perhaps I must eliminate it.
Bye
The Following User Says Thank You to covarxi For This Useful Post:
oldbeaver (12-15-2010)
Old 02-10-2010, 06:48 PM   #2 (permalink)
recession proof rebel
k.civic.f4i's Avatar
nicely done. reminds me of mcrews setup
how to.....
http://ecomodder.com/forum/showthrea...cks-11998.html
http://ecomodder.com/forum/showthrea...how-12301.html
true wealth comes from good health and wise ways
Old 02-10-2010, 06:51 PM   #3 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Accord LX
90 day: 35.57 mpg (US)
i like.
i bought'd thicker lexan, thinking i;d make time to properly trim it so it would fill and recess (but stay flush) into the odd shape of my grill. plus i will need to leave an opening to access the hood release.
i;ve not made time to trim this for 2 months. i was using blue painter tape on my grill until a couple weeks ago.
single person car thread
Old 02-10-2010, 08:17 PM   #4 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
There are a lot of grille blocks in this area. Cardboard and twist ties are not rare. The most popular type is plain stainless steel sheet with a few small slits, apparently robot-cut for many popular trucks. The older classic is the more universal, overall-coverage black, quilted type with a few flaps that can be tied up on warmer days. I've yet to see any stealthy blocks - running without one here is a bad maintenance, or laziness.
Old 02-11-2010, 02:10 AM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
You should experiment with making the block smaller. Once you know how large it should be at what time of the year, you can make different blocks for summer and winter, or add an extra winter cover to the summer block.
Since you have a turbodiesel, it is probably quite efficient, so it takes a long time to warm up, and doesn't overheat too often (especially if you ecodrive). This should let you get away with at least a partial block for most of the year.
Have you blocked the lower grille, under the bumper? Start blocking from the sides and work your way towards the center. If you can, keep the upper grille blocked year round and experiment with the lower grille. You may also try an openable block, such as mine:
You can read about it here in my modding thread.
Piwoslaw's Peugeot 307sw modding thread
Old 02-11-2010, 05:07 AM   #6 (permalink)
Thanks Piwoslaw,
I leaved open the lower grille because in the mediterranean coast (where I live) outside temperature is allways positive.
Now I will check engine temperature in warmer days and I'll consider your modd if needed.
And old version of 'adjustable' grill block.
The Following 2 Users Say Thank You to covarxi For This Useful Post:
aerohead (12-27-2010), mango (02-11-2010)
Old 02-11-2010, 08:34 AM   #7 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
Those openings are enormous.
Old 02-11-2010, 04:41 PM   #8 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Very clean looking modification. Added to the project library.
Old 02-12-2010, 02:44 PM   #9 (permalink)
Eco Amateur
AeroCav - '03 Cavalier
I like the clear look, makes it less noticable on the road and thus less stares. What kind of plastic did you use and where did you happen to purchase it?
Old 02-12-2010, 03:53 PM   #10 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
spydyr -
+1. And the thickness. I always ask how thick the material is. Always.
CarloSW2
American Solar Energy Society
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 02:03 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 03:09 PM
