02-02-2011, 12:08 AM
#131 (permalink)
Ecomodder en route
Vib - '04 Pontiac Vibe base
Here, I think this should be of help to you...
R and R of Roof Rails
02-02-2011, 12:37 PM
#132 (permalink)
Deadly Efficient
Thanks, KITT222
Removing the rails is not the problem. What that link doesn't show is what to do with the gaping hole on either side of the lift gate afterwards!
I plan on removing them, but not until it's warm out.
-Terry
02-02-2011, 05:19 PM
#133 (permalink)
I had good success using rubber well nuts from the local hardware store to fill the hole from a removed roof rack on a Blazer years ago. The rubber swelled to seal the hole, and with a stainless screw, there was no rust or corrosion to deal with.
Current MPG driver:
1994 Isuzu Rodeo - Beater with a Heater...
02-02-2011, 05:25 PM
#134 (permalink)
Ecomodder en route
02-07-2011, 08:15 PM
#135 (permalink)
Deadly Efficient
I installed an oil pan heater. It's a Katz brand 50watt unit I bought on eBay. Now the bottom end will enjoy warm oil at start up, as well as the coolant being warmed in the head by the block heater.
I just wish the Scangauge would read out oil temp.
-Terry
03-10-2011, 12:28 AM
#136 (permalink)
Deadly Efficient
Got my wheel discs installed...finally. Tomorrow will be the first day of commuting with them on.
-Terry
03-10-2011, 06:12 PM
#137 (permalink)
Nice look!
03-10-2011, 06:37 PM
#138 (permalink)
Agreed, very nice. How did you attach them? I see 5 screws on each? Into the lugnuts?
03-10-2011, 09:23 PM
#139 (permalink)
Deadly Efficient
Yup. 10-24 stainless steel screws thread into locknuts that are J-B welded into the acorn lugnuts,ala NachtRitter. I liked the look of the bare metal pans, so I coated them with some spray-bomb clear coat.
-Terry
03-10-2011, 11:43 PM
#140 (permalink)
Ecomodder en route
Those wheel covers look great! They help the give Olivia that extra aesthetically-aero look. The grill blocks and such all look great as one.
