View Poll Results: What diameter tires you are running on. (choose closest option)
Bigger diameter
5 |
17.86% |
P235/75R15 Diameter = 733 mm = 28.85 inch
1 |
3.57% |
P225/55R17 Diameter = 679 mm = 26,73 inch
1 |
3.57% |
P215/60R16 Diameter = 664 mm = 26,14 inch
1 |
3.57% |
P195/60R15 Diameter = 615 mm = 24,21 inch
4 |
14.29% |
P185/65R14 Diameter = 596 mm = 23,46 inch
7 |
25.00% |
P145/80R14 Diameter = 587 mm = 23,11 inch
3 |
10.71% |
P175/70R13 Diameter = 575 mm = 22,64 inch
4 |
14.29% |
P155/70R13 Diameter = 547 mm = 21,54 inch
1 |
3.57% |
Smaller diameter
1 |
3.57% |
09-11-2011, 04:14 PM
What diameter tires are you using at the moment?
I need some back up data on ecomodders tires when I will go to nokiantyres to talk about some special purpose tires which I will need on my Lupo 3L. I suggest that they would make about 5 different sizes with about 8% diameter steps :/.
You can legally change the diameter of tire 5% to each direction in EU, is it the same in the states?
Oh and the new very low rolling resistance nokian tire is not yet on the market  .
09-11-2011, 04:23 PM
25.5"
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
09-11-2011, 04:26 PM
Driving the TurboWeasel
25" or so, the ones the came on the car OEM. 215/55-17.
2012 Chevrolet Cruze Eco 6MT
09-11-2011, 05:17 PM
Pishtaco
25.07" (P205/50-R17). OEM were P185/60-R15, 23.7" diameter. New tires are 5.31% taller. US mfrs don't recommend going above 3% taller.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Clean Green Toaster Machine
45.8 mpg over 2235 miles, 164% of '08 EPA
09-11-2011, 05:35 PM
...beats walking...
...OEM on our 2011 Cruze LTZ is P225/45R18 on "flangeless" alloy rims.
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970˝ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
09-11-2011, 05:39 PM
Pokémoderator
Vekke -
195/65 15, one size up from stock, about 2+% larger diameter and 1 lb heavier than stock. I don't know of a specific law in the USA that prohibits tire size change. It's more a physical thing of fitting in the wheelwell. I could have fit two-sizes up from stock for a 4% larger diameter, but the tire jumped to 3+ lbs heavier.
CarloSW2
09-11-2011, 06:20 PM
V8 guy
In the US we can do pretty much what ever we want with tire size as long as it with in reason.
On my car I run P225/60R16.
Taller and narrower that the dead (245/45) 16 inch OEM size my car came with.
On the truck I use 31x10.5R15. That is between 2 to 3 inches taller a little wider than what it left the factory with. I went taller for less rotations per mile and wider for the load rating.
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
09-11-2011, 07:02 PM
I'm running the very popular 205/55/16 24.87 in 631.69 mm diameter
Can't do a range of tyres in Europe without this size.
(As an OEM alternative to the stock 195/65/15 24.98 in 634.49 mm.)
In Belgium, we're limited to - 2 % and + 1,5 % differences in tire diameter.
It definitely needs testing then.
09-11-2011, 08:10 PM
#9 (permalink)
Dumb question everyone,
has anyone noted a significant gain in MPG's due to lower cruising RPM's with bigger wheels, in spite of possible losses in aerodynamics and gains in weight?
09-11-2011, 10:04 PM
#10 (permalink)
Pishtaco
Yes. Tall tire test. Note page 1 of that thread shows the heavier, less aerodynamic wheels/tires don't give significantly worse performance than the OEM stockers.
Darrell
