View Poll Results: What diameter tires you are running on. (choose closest option)
Bigger diameter 5 17.86%
P235/75R15 Diameter = 733 mm = 28.85 inch 1 3.57%
P225/55R17 Diameter = 679 mm = 26,73 inch 1 3.57%
P215/60R16 Diameter = 664 mm = 26,14 inch 1 3.57%
P195/60R15 Diameter = 615 mm = 24,21 inch 4 14.29%
P185/65R14 Diameter = 596 mm = 23,46 inch 7 25.00%
P145/80R14 Diameter = 587 mm = 23,11 inch 3 10.71%
P175/70R13 Diameter = 575 mm = 22,64 inch 4 14.29%
P155/70R13 Diameter = 547 mm = 21,54 inch 1 3.57%
Smaller diameter 1 3.57%
Voters: 28. You may not vote on this poll
Old 09-12-2011, 12:08 AM   #11 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
LT 235-85Ex16 OD=31.7"
OEM-sized rubber.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 09-12-2011, 04:11 AM   #12 (permalink)
BikerModder's Avatar
Deedee - '09 Smart ForTwo Pure 999cc
90 day: 47.39 mpg (US)
Low rolling resistance is anything not "knobby". Because of the laws affecting styles of bumpers and tinted windows and everything on up... Bumper law in at least 9" for certain jurisdictions. Tires we go by the manual. A light enough tire-would help in town and a larger diameter would help lower the revolutions (RPM) for touring. I keep hoping a high mileage compound would come out with the 100,000 mile range would be introduced with hopefully the aerospace technology and industrial process. Maybe gray.
Old 09-12-2011, 04:59 AM   #13 (permalink)
i went from stock 215-45-17 24.5 " to 225-40-18 25.1" didnt notice alot of difference my car is not ideal for fe though
Old 09-12-2011, 05:20 AM   #14 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Originally Posted by cfg83 View Post
Vekke -
195/65 15, one size up from stock, about 2+% larger diameter and 1 lb heavier than stock. I don't know of a specific law in the USA that prohibits tire size change. It's more a physical thing of fitting in the wheelwell. I could have fit two-sizes up from stock for a 4% larger diameter, but the tire jumped to 3+ lbs heavier.
CarloSW2
At lest on my lupo I can barely fit even 12% taller with only minimal rubbing on normal driving. I have plans to suggest totally new tire design to them, what I have in my mind. It will have 3 things which will make it ultimate eco tire . But I need to discuss with their techichians if those changes are possible to manufacture like they work on my tiny head... They will also be lighter but thats not one the three things...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 09-12-2011, 06:25 AM   #15 (permalink)
Originally Posted by echoRS View Post
Dumb question everyone,
has anyone noted a significant gain in MPG's due to lower cruising RPM's with bigger wheels, in spite of possible losses in aerodynamics and gains in weight?
Very true. On my truck I went from a 235/75/R15 that weighed about 25lb that held 35psi of air to my 31/10.5/R15 that weigh about 40lb and held a max of 50psi of air (I keep about 40 in them) and saw no loss in MPGs. If any thing they went up slightly.
I believe it was due to the better drive ratio and lower rolling resistance from being able to put +5psi in them. (when the truck is loaded I N2 them up to 50psi)
I tested them in combinded city + highway and highway only driving.
The result was unexpected to say the least.
Old 09-12-2011, 08:17 PM   #16 (permalink)
I went about 4% larger than stock. I went from 22.7" diameter (what was listed for one particular 185/60-14) to 23.7" (what is listed for my specific 175/70-14s). Note that tires can deviate from the "calculated" size, which is why getting a specific rolling diameter or revs/mile figure from the manufacturer is more accurate than calculating the diameter from the section width, aspect ratio, and rim diameter.
-soD
Old 09-13-2011, 10:57 AM   #17 (permalink)
The PRC.
Skinny 155/65x14s.
Old 09-13-2011, 03:47 PM   #18 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
175/70-13.
They're getting harder to find. Only the base model 1996 had this size, and the 97 went up to 14's on all trim levels.
Old 09-13-2011, 04:18 PM   #19 (permalink)
Kodak's Avatar
Canyon - '07 GMC Canyon 2wd regular cab
90 day: 24.95 mpg (US)
Stock size. P225/75R15 (I chose 235 on the poll for closest size).
Different configurations of Canyons were sized differently (I think 205 on the work trucks and 235 for some others).
EcoDriving: Turning more fuel into usable forward motion.
Old 09-13-2011, 08:08 PM   #20 (permalink)
13s are a dead rim size. They use to be very popular and made in the USA.
Best bet might be to move up to 14s.
