07-13-2013, 07:06 AM
#101 (permalink)
very nice,if money wasn't a issue a light weight motor home that retracts into itself,making a narrow streamlined vehicle with as low CD.When you park it spreads out.Easy to build but expensive parts,most hand machined.
07-13-2013, 01:37 PM
#102 (permalink)
Wow!!!!!!!!!!!!!!!!!!!!
Originally Posted by botsapper
Makes one want to weep! Thanks for all the data-mining.
07-13-2013, 04:44 PM
#103 (permalink)
Thanks botsapper and aerohead!
I guess Opera is broken. When I follow the link in Opera I get a blank page and when I reload (having Opened in a background tab) I can see a flash of the Futureliner before it goes blank again.
So I opened it in Safari and was able to see it. I wouldn't have tried absent aerohead's endorsement.
In the comments:
07-21-2013, 10:20 AM
#104 (permalink)
kach22i, that vixen looks best when pictured over the black coroplast
As for the original question I can't offer much, as I will always be a Tow Vehicle/trailer kind of guy.
I can build the lowest floor with one of those. Low floor = low height and frontal area.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
07-21-2013, 05:35 PM
#105 (permalink)
Notice how the rear bumper is notched out to clear the door? Everything below the rocker panel is the plumbing drain or drain pipe storage.
07-21-2013, 06:11 PM
#106 (permalink)
Do you own that, Freebeard?
2003 TDI Beetle
2002 TDI Beetle
07-22-2013, 03:53 PM
#107 (permalink)
--Admitted on page eight--
More like 'Are you still dragging around that ball-and-chain?' I'm really tempted to jack it up, drop the front sub-frame out and put a temporary tongue and hitch ball on it and scrap the rest.
Behind a rusted out pickup truck body, it would make a kick-@ss bobber truck. See also the reverse trike motorhome in the above post.
07-22-2013, 05:40 PM
#109 (permalink)
Too bad that Cortez is so rough. I have the *perfect* engine for it here, an Isuzu 4BD1T 3.9 turbo diesel. build an adapter and viola, a few more MPGs.
2003 TDI Beetle
2002 TDI Beetle
11-02-2013, 11:12 PM
#110 (permalink)
The Following User Says Thank You to ennored For This Useful Post:
