Old 02-26-2008, 11:53 PM   #1 (permalink)
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
You know it's cold when....
OK.
I am NOT MAKING THIS UP!
You know it's cold when......
1) You can't take your forklift apart because the blizzard keeps making your socket set disappear.
2) You can't plug in your block heater because the cover is frozen on.
Both of these have actually happened to me.
Do you have a TRUE "you know it's cold when"?
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 02-27-2008, 12:22 AM   #2 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
It's 72 degrees outside right now... according to my thermometer.... :shrug:
Challenge me, or correct me, but don't ask me to die quietly.
Old 02-27-2008, 01:15 AM   #3 (permalink)
Peakster's Avatar
'99 Intrepid - '99 Intrepid
90 day: 23.1 mpg (US)
There's a dense fog covering the city from exhaust outlets in every car and building.
Today was only about -10*C though, practically T-shirt weather .
Old 02-27-2008, 01:33 AM   #4 (permalink)
Wannabe EcoModder
Epic Wins - '07 Masi Vincere
Send a message via AIM to GenKreton
If it's snowing, it's not that cold
(I feel I should add, I know it's not the cold directly that causes the lack of snow at lower temperatures but too much dynamic stability...)
Old 02-27-2008, 01:34 AM   #5 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
I put my winter coat away when it reached -10F figiring that it was summer already, but it's still cold enough that my clutch is slow to engauge, and it takes 5+ miles for my temp gauge to read anything, or heat to come out of the defrost.
Old 02-27-2008, 08:32 AM   #6 (permalink)
"Crush"
bennelson's Avatar
S10 - '95 S10
It is actually a myth that it gets "too cold to snow" - it just happens to be more rare when it is both really cold AND snowing. It doesn't snow much in Antarctica because it's a desert, NOT because it's cold.
Don't forget to factor in wind-chill!
My YouTube Videos
The Following User Says Thank You to bennelson For This Useful Post:
Cd (02-03-2012)
Old 02-27-2008, 09:02 AM   #7 (permalink)
Who
UnderModded
Pablo - '07 Santa Fe AWD
90 day: 23.62 mpg (US)
I wouldn't call it a myth, I'd say just more of a norm for weather.
Weather tends to be clear and cold (high pressure) or warm and wet (low pressure).
Old 02-27-2008, 10:38 AM   #8 (permalink)
pontiac trans am - '00 firebird trans am
jeep 1 - '02 wrangler
90 day: 16.76 mpg (US)
jeep 2 - '07 wrangler x
90 day: 19.39 mpg (US)
Toyota - '09 Corolla lx
not as interesting or funny...
you know its cold when neither of your vehicles want to start (cranking for 5-10 secs )
Old 02-27-2008, 01:14 PM   #9 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
You know it's cold when you can pour liquid propane in a glass.
As for the "too cold to snow" statement, I'm with Who on that one. I can't remember the last time it was -30 and snowing here. With the global warming trend, we are expecting to have even MORE snow in the winter around here as the mean temperature for the winter goes up towards 0.
Edit: All temps in Celcius
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 02-27-2008, 01:42 PM   #10 (permalink)
Wannabe EcoModder
I was trying to avoid this, hence my footnote, but if you want to get technical, -20F it's too cold for most snow to happen. At -40F you can get snow but without nuclei, but it's nothing like the snow we commonly experience - it's significantly smaller.
Around -5F there begins to be an extreme lack of vapor in the air, that is it snows before it hits the air mass at this temperature, often on the front, because the colder mass isn't capable of holding that amount of water - that's what the dew point is all about. Saturated air is capable of reaching Antarctica, and may soon in coming years if it warms up. Besides the fact no saturated air makes it over the region, its cold enough that even in sunlight, little water evaporates and therefore little precipitation can ever occur. Add to that the temperature gradient is minimal promoting dynamic stability, it becomes impossible for it to snow under these temperature conditions.
Parts of Vermont are getting hammered with snow this year because it is warmer than normal. Normally the moisture encounters the Arctic/Canadian air mass and falls before it can get to us, but not this winter...
Cold air VS Warm Air Intakes - what's the difference? deadman1474 EcoModding Central 49 03-25-2012 10:47 PM
Disconnected Idle Air Control - for lower RPM after a cold start Lazarus EcoModding Central 19 04-15-2011 03:50 PM
Winter cold start & idling warm-up experiment MetroMPG Hypermiling / EcoDriver's Ed 17 12-17-2010 03:39 PM
MetroMPG.com mailbag: Metro engine won't stay warm in super cold weather MetroMPG General Efficiency Discussion 13 02-01-2008 11:28 PM
You know it's REAL cold when... Peakster The Lounge 13 01-22-2008 02:23 PM
