Old 08-15-2012, 11:22 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
CRX HF Trans Swap in a Civic Wagon (1800 RPM @ 60 MPH vs. 2800, and ~19% better MPG)
I've had a 1989 CRX HF transmission in my 1991 Civic Wagon for about two weeks now. It's a direct swap. Based on measured rolling circumference of my 185/65-14" tires, I'm now turning 1800 RPM at 60 MPH. That's a welcome change from the 2800 RPM the engine used to spin. 2000 RPM now gives me 65 MPH instead of only 43 MPH. My new 3rd gear is slightly taller than my old 5th gear!
Other than first gear, every ratio is a lower numerical ratio. If you think a 3.52 Metro/Swift final drive is tall, try a 2.95! The 88-91 2WD Wagons came with a 4.058 final drive.
First gear is now halfway between the old 1st and 2nd gears. Not as bad as it sounds. But it does take more slipping of the clutch, especially on hills. I ordered a new Exedy/Daikin clutch disc before pulling the old trans. Not surprisingly, my 198k mile clutch was down to the rivets on the pressure plate side. I reused my old pressure plate and the throwout bearing that came with the HF trans. I'm sure both will outlast the rusty body.
The HF came with smaller tires than the Wagon. Which means the speedo gear is different. NY rust and corrosion prohibits me from swapping the speedo gears, so the speedometer and odometer are now off by 5%. That's based on the sizes of the speedo gears and GPS-verified. So I'm adding 5% to my miles for MPG calculations. 165/65-14" Insight tires would fix this if I could find them used.
Coasting in neutral isn't much different than coasting in 5th gear now!
I have Mobil 1 0w-20 in the trans right now. It shifted slightly better with my old Honda OEM fluid in there, but I'm not about to drain $20 worth of oil.
I recently drove out to Ohio for GeoPalooza (yes, in a Honda) and drove the speed limit with almost no hypermiling. Average speed was 54 MPH. Removing the first 100 or so miles from that tank that were hypermiled, I got something like 44 MPG. That's a pretty good improvement from the 37 MPG this car used to get at those speeds. I'm guessing the trans swap is a big part of that. I'm not expecting much, if any, improvement while hypermiling at low speeds. I did the swap to reduce the penalty of higher speeds.
I've noticed two issues with the trans. One is a growl in 1st gear if I let off the throttle. The other is a leaking shifter seal. Does anybody know if that seal is replaceable from the outside? I don't see anything about the seal in my factory manual.
I think the total cost was around $150. I'll probably never make that back before the car rots away, but I'll still have the trans.
Do not do this swap if you drive mostly in the city! I'm not even sure if I'd want this trans in an HF in the city. But it's amazing on an open road, even if I end up keeping it in 4th gear at my slower speeds.
Here are the overall ratios (gear ratios multiplied by final drive):
And the old clutch:
And with the old trans out:
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following 4 Users Say Thank You to Gasoline Fumes For This Useful Post:
California98Civic (08-26-2012), MetroMPG (08-16-2012), PaleMelanesian (08-16-2012), Ryland (08-16-2012)
Old 08-16-2012, 09:34 AM   #2 (permalink)
Hypermiler
PaleMelanesian's Avatar
PaleCivic (retired) - '96 Honda Civic DX Sedan
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Nice work! I just replaced my axles and that view of the engine bay from underneath looks VERY familiar. They didn't change much in the following years.
What tools and techniques were required for the removal and installation?
11-mile commute: 100 mpg - - - Tank: 90.2 mpg / 1191 miles
Old 08-16-2012, 11:51 AM   #3 (permalink)
Fumes: great writeup! Thanks for posting all the details.
Nice preliminary results too.
On your comment about the "tallness" of the Suzuki 3.52 vs. HF 2.95, I still sometimes wish I had a taller 5th gear for the Metro (but definitely not a taller f.d.).
Old 08-16-2012, 02:56 PM   #4 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
The HF 5th gear is 0.694 versus my old 0.771. If I did a lot of city driving, I'd want only the HF 5th.
I supported the trans with a floor jack and the engine with an engine hoist. Once I had the mounts, axles, linkage, and other stuff disconnected from the trans, I pulled it away from the engine and lowered it with the jack. I had to disconnect both lower ball joints and unbolt the radius rod on the right side of the car to get the trans out. The floor jack in the picture is there because the hoist won't stay up for very long.
Getting the "new" trans on was a bit difficult. Mostly because I had a hard time getting it lined up so the trans input shaft would go straight into the clutch. Then it suddenly just went right in. I used a couple of trans-to-engine bolts with the heads cut off as alignment pins, that helped a lot!
There were a few times I wondered if pulling the engine and trans out together would've been easier.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Old 08-16-2012, 03:08 PM   #5 (permalink)
I had exactly the same experience when I swapped transmissions: difficulty getting it to slide nicely back together. Much fiddling, swearing, sweating. Then ... voila!
Old 08-16-2012, 05:43 PM   #6 (permalink)
Just a tip on the next trans you may do..
When you use the clutch alignment tool, lift on it just a tad and then bolt down the pressure plate.. Then probe the clutch and flywheel with the alignment tool to make sure everything is smooth.. Just because you use the tool doesn't mean its lined perfectly.. Ive fought a few transmissions and doing this have yet to fight another one to get in the hole..
The Following User Says Thank You to 02ws6 For This Useful Post:
Gasoline Fumes (08-16-2012)
Old 08-16-2012, 09:36 PM   #7 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
I didn't have a alignment tool, I was using a socket wrapped in electrical tape. That could've been part of the problem, but I know I didn't have the trans lined up very well with the engine at first. It went right in once I got it straight.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 08-17-2012, 05:58 PM   #8 (permalink)
wyatta4's Avatar
CRX:HF - '89 Honda CRX HF
90 day: 53.05 mpg (US)
NameGoesHere - '15 Volkswagen Golf TDI SEL
This sounds like an awesome car! Nice work!
Check out my project here---> 1989 CRX HF
Follow me on Twitter. @secsieAzul
Old 08-17-2012, 07:19 PM   #9 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Hondas are great to tinker with. In the saturn, the whole sub frame and suspension have to come to the change the trans, a real pain.
- Tony
