Originally Posted by adamj12b
Clev,
Dot forget I am removing the THM-400 automatic transmission that weighs 134 lbs without torque converter and fluid.
This will be replaced with a T10 transmission. I actually have 2 T10's, 1-3 speed and 1-4 speed. The 3 speed is almost brand new with only a few thousand miles on it. The 4 speed is unknown condition and will be gone through and parts replaced if needed. The 4 speed weighs about 70lbs dry. Thats about half the weight of the THM400.
Cool, even better.
Most EV's use just a couple of gears, so if you can get a good combo of ratios in a 3-speed, I'd use it and save having that fourth unused gear spinning around. Plus, a newer unit will probably have better bearings that will waste less electricity.
