Old 06-20-2011, 04:47 PM   #57 (permalink)
JeepNmpg2
Jeep Ecomodder
JeepNmpg2's Avatar
Daddy's Jeep - '00 Jeep Cherokee SE
90 day: 19.66 mpg (US)
Mama's Kia - '06 Kia Sedona LX
Originally Posted by FastPlastic View Post
I used galvanized steel. So far unpainted in many places it's holding up well. Only spot that is rusting directly contacts the exhaust pipe, which really didn't surprise me. You can find it in the heating and cooling section of lowes/Home Depot. It's thick enough that in smaller pieces it will hold its shape, and only cost about $7-$10 a sheet.
Do you think I would need that particular section to be only the Galvanized Steel, or would it work as a heat shield of sorts if I used a few rubber washers to space it above the coroplast around the exhaust pipe areas?
