Old 06-20-2011, 12:17 AM   #51 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Daddy's Jeep - '00 Jeep Cherokee SE
90 day: 19.66 mpg (US)
Mama's Kia - '06 Kia Sedona LX
Originally Posted by slowmover View Post
21.4 is not that different from what we saw in our first 2WD '01 (stock, A/C, 3 pax, loaded, 70-mph). Am enjoying this thread as we still have (another) one.
In that case, I'll happily quote Mr. Sheen..... "Winning!"
Mine is pushing a 4WD drivetrain, 400 lbs of bumpers and armor, 80 lbs of tree pulling/idiot rescuing winch, and a definately not-so-aero bullbar.
Actually, maybe I could pick up some polycarbonate and heat form a grill block for the bullbar that my lights can still work through.... Each bullbar verticle conveniently has about a 3/16 'lip' that could securely hold one side of some lexan.
1. How does this look to those of you who've done grill blocks? Success or failure doesn't matter as long as you learned from it.
2. Does this appear to be enough airflow for the radiator?
I'd especially like to hear from you FastPlastic. This does not actually block the grill openings off, but redirects the oncoming airflow around the vehicle so it can still suck air as needed.
Name:	Jeep Grill Block Idea.jpg
Old 06-20-2011, 12:32 AM   #52 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
You can check my photo album to see what grill blocks I have on my Jeep, granted I don't have a full set of bumpers and armor, but still. With a gap behind the bull bar you might actually hurt the aerodynamics(don't quote me on that one though), might be better to go with what I did.
Old 06-20-2011, 12:44 AM   #53 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
I was thinking the same thing initially, but I've got a nagging feeling that the getting the majority of the airflow around the convoluded nose full of lights, bars and so forth will pay better dividends than just blocking part of the grill.
Old 06-20-2011, 12:50 AM   #54 (permalink)
one way to find out
Old 06-20-2011, 03:36 PM   #55 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Lifting a vehicle for better MPG?
Originally Posted by JeepNmpg2 View Post
Tomorrow I'm picking up the materials for the bellypan for this weekends work before the upcoming trip.
Got a bit overzealous there, I actually did some detailed measuring this morning and extrapolated out that my exhaust downpipe would be roughly .25 to .5 of an inch from the coroplast - which is a definate no-no.
Here's the real kicker, who would have thought that I'd have to lift my vehicle an inch for ecomodding purposes? Just kidding, I'm looking for an alternative material for that area like some kind of sheet stock. Other than that, it will be the same M.O. of angle aluminum stock and rivets.
Old 06-20-2011, 03:44 PM   #56 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
I used galvanized steel. So far unpainted in many places it's holding up well. Only spot that is rusting directly contacts the exhaust pipe, which really didn't surprise me. You can find it in the heating and cooling section of lowes/Home Depot. It's thick enough that in smaller pieces it will hold its shape, and only cost about $7-$10 a sheet.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 06-20-2011, 03:47 PM   #57 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Do you think I would need that particular section to be only the Galvanized Steel, or would it work as a heat shield of sorts if I used a few rubber washers to space it above the coroplast around the exhaust pipe areas?
Old 06-20-2011, 03:56 PM   #58 (permalink)
I would recommend using it at least directly under the exhaust(maybe give yourself a 8-12" wide strip). You're talking about a lot of heat up there so it's best if you can dissipate some of it.
Old 06-24-2011, 07:24 AM   #59 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Aeromod mudhole durability test
Well, I was playing around in the mud yesterday and ended up finding a "Georgia clay" sinkhole that buried me up to my door sills (could still open the door by about 1/2 and inch (not what I had intended). Normally I wouldn't post this on Ecomodder, however, it ended up directly testing how sturdy my mod ended up being.
I ended up having to winch myself at nearly a 90 degree angle, which I figured would for sure shear off my mod as it was a good 6-8 inches in the muck but it turns out I built in a failsafe by mistake:
Front - you can see the left side of the air dam pushed up about an inch, exposing more axle
Right side - support arm still fully intact and straight
Left Side - support arm pivoted at the bolt, allowing the pressure not to break the angle alluminum supports.
Here's an after picture of the whole vehicle after the ordeal
I am extremely pleased with this outcome, now if I can only get my other projects finished.
Name:	Jeep Front Mud Bath.jpg
ID:	8793   Click image for larger version
Name:	Jeep Mud Bath 2.jpg
ID:	8794   Click image for larger version
Name:	Jeep Mud Bath 3.jpg
ID:	8795   Click image for larger version
Name:	Jeep Mud Bath 4.jpg
Old 06-24-2011, 06:28 PM   #60 (permalink)
90 day: 19.36 mpg (US)
Pleased that you posted this. I anticipate that leaving ahead of the crowd -- hopefully -- in the event of a hurricane may cause me to have to "offroad" briefly at one point or another. I've specifically bookmarked your thread, now, under two categories, for two different vehicles.
BOAT TAIL Drag Reduction Estimates aerohead Aerodynamics 12 01-30-2016 04:08 PM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 9 01-19-2014 09:59 AM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph MetroMPG Aerodynamics 500 05-10-2012 10:30 PM
Trailer Hitch Boat Tail? superchow EcoModding Central 16 04-26-2010 02:35 PM
Off-Road Test: '08 Jeep Grand Cherokee (Rally Race) RH77 The Lounge 4 02-25-2008 03:59 PM
