Originally Posted by JeepNmpg2
Do you think I would need that particular section to be only the Galvanized Steel, or would it work as a heat shield of sorts if I used a few rubber washers to space it above the coroplast around the exhaust pipe areas?
I would recommend using it at least directly under the exhaust(maybe give yourself a 8-12" wide strip). You're talking about a lot of heat up there so it's best if you can dissipate some of it.
