Old 08-12-2011, 09:56 PM   #24 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
Originally Posted by orbywan View Post
BZP, yes I know, this stuff is expensive. We have to use really good quality components because everyone tends to beat the heck out of this stuff, plus we frequently build the system to the customer’s specs. Not to mention the fact that if you have any problems or need advice on how to install it you get me or one of my techs on the phone in a heart beat instead of sending emails and trying to find a phone number to call someone who has a pulse and has a clue what they’re talking about.
The pan and tilt systems are designed specifically for mounting on the back of motor homes and big trucks. The housings are 6 inches in diameter, have 180 degree + panning and about 100 degree vertical movement (anything higher and you’re just looking at the clouds).
The easiest way to describe them is if you duct taped a spotter on the back of an RV or big truck, these cameras can see anyplace your spotter could look. Up, down, sideways, and anywhere in between. Zero blind spots. They have a control cable going to the dash area, and a remote control panel that mounts on the dash. If you use the 8-camera switcher, it also has a control pad. I attached some photos of various coaches and dash layouts, including some shots of the side cameras and nosecams we use on the RV’s.
Retail cost of a pan and tilt system right now, without a monitor, directly from the factory is $1250. We build them right here in Arizona using the best components and good old American labor. There are about 35 different RV manufacturers, Prevost converters and specialty builders using them these days. You can see a list and get more info at the site I gave you before, www. totalvisionproducts.com.
I’m trying to understand exactly what you referred to about ‘nose, left/right on the aero cap’. Can you explain that a little? Knowing what kind of vehicle you’re going to put them on would help a lot. There are on average 10 or 20 cameras that will go on any given location, and usually one or two that are actually the best for that location. When you say ‘nose’ I assume you’re talking about a front mounted camera on your vehicle, but I’m lost with the ‘left/right on the aero cap’, sorry, can you explain that a little?.
Sorry...was kinda thinking out loud.
My aero cap build thread...
http://ecomodder.com/forum/showthrea...dea-15137.html
Yes...nose = front part of the hood of the Toyota T-100 pickup truck. Not sure I'd want something in the license plate arena...too low fer my liking.
Since I don't have any windows in my current aero cap build/config, I was looking at some cameras to look out the sides/back/blind spots with. I'm not at a stage where I could install expensive cameras as someone could easily remove them with a knife cutting through the Coroplast. But at least I know where to look to fer some great gear when/if the time comes.
Dark Aero-The world's first aerodynamic single wheel boat tail!
