Old 08-17-2011, 12:30 PM   #12 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
May delete lead acid battery and replace it 2 or 3 parrelled lithium packs used in motorcycles and ATVs, replacing a 35-40lb lead battery with 2 or 3 minipacks that weigh about 5lb each.
I like this idea. I have seen some small deep cycle batteries that are still fairly light... I wonder.
Originally Posted by 320touring View Post
I'm thinking of trying to come up with a way to remove 100kg from the 318iS and the 320i that DOESNT affect the look, fit or finish of the car.. anyone any ideas?
I would look to the sound system (for substitutions that are lighter) and to the engine (also for lighter substitutions). Body substitutions, such as using existing body parts as a plug for a mold for fiberglass fabrication of identical, paintable parts that are lighter (trunk, fenders, hood would probably be easiest). Lightweight aluminum pulleys of the same sizes, like wheels, would reduce effectively twice as much "weight" by reducing twice their weight in rotational mass. These are ideas I have. My car is like an ancient Buddhist temple that monks are gradually completely rebuilding in replica as the parts rot or break.
320touring (08-18-2011)
