Old 08-22-2011, 08:50 AM   #159 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Originally Posted by gor View Post
so, Ben, what is your impressions and thoughts after a while of running it?
Well, a couple of things.
To start off, there's still something not quite right with that generator. It just konks out on me whenever I put too much load on it. It should be able to get up to a certain RPM and current level, and it just never does.
Aside from that, the entire CONCEPT of the system works pretty well.
The reality of it is that I REALLY LIKE how quiet an electric car is. Having the generator run is NOT quiet. Also, the Metro trunk space isn't large at all - the generator setup takes up nearly the entire cargo area - whether you are even using it or not.
The other thing is that the generator is NOT large enough to run the motor directly. That means that the generator can only extend range by some percent, so the batteries are still the limiting factor, not the generator's fuel supply.
Also, the generator system was an after-thought to the entire car. If the car was designed as a hybrid to start with, it would have been easier to integrate and make everything work together a little better.
In the end, I think it either ends up in the style of a Nissan Leaf (just lots of good batteries, with good all-electric range) or that of a Chevy Volt ( some electric-only, but really with an engine big enough to push the car down the road.
Right now, I am leaning towards putting more bigger better batteries in the car. I also really need a new battery charger. My old K&W died on me a while ago now. I've been very busy with the baby, work, and my other responsibilities to do much work on the car lately.
Overall, I like the idea of the serial-hybrid concept, but think it requires just the right size generator, better integration (get the generator under the hood) and some more sound-proofing.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
