Old 10-20-2011, 05:38 PM   #24 (permalink)
oil pan 4
The lithium battery starts my car just fine.
I have a gear reduction starter so I am sure that helps.
The battery voltage doesn't really drop much below 12 volts when cranking.
This mod works out pretty well because now I have an air intake running where the lead acid battery use to be and the lithium is being relocated to the back seat.
