Old 06-01-2012, 02:06 PM   #13 (permalink)
oil pan 4
Originally Posted by rmay635703 View Post
The best were the C-code 82-84 motor because of the small cups, if you make a frankenstein using the smaller cups on a newer motor (like a 6.5 for example) you can improve its fuel economy at the expense of a bit of power.
That is what I have, a 6.5L block with 6.2L everything else. I kept the C-code heads for this reason.
