Old 01-11-2014, 09:44 AM   #3 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Welcome!
I generally only see 30-40 degrees above ambient temps with a standard type warm air intake, the kind that pulls air from near a hot engine part, such as the exhaust manifold. There are guys on here who have produced really good results with a moderately more complex mod in which they install a heater core into the intake air stream, allowing hot coolant to heat air before the filter, before the intake manifold. That kind of set up reports higher temps--don't go too high--and more importantly gives stable temps that can be high even in the winter. The more crude kind will probably rarely supply more than 30-50 degrees F above whatever ambient is, according to the season.
How much power does the CRZ headlight system draw? Isn't it LED?
zingaro (01-11-2014)
