Old 08-13-2014, 10:44 PM   #13 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Kill switch.
Agree
Originally Posted by dirtydave View Post
Ac and power steering delete maybe even an alternator delete or you could probably leave the belt off if you only drive 5 miles to work.
Agree
Originally Posted by basjoos View Post
Engine block heater
Full grill block that can be partially or completely opened by the driver...
...reduce weight, decrease rolling resistance, and reduce the time it takes for your engine to heat up to normal operating temps will help. Aerodynamic improvements will help but are less dominant at those speeds.
Agree
For a short commute, you could remove the front passenger seat to get rid of 35 or so lbs.
In my experience with the exact gearing you will get from your VX trans, unfortunately, it is not better for stop and go driving. It is best at 55-65 mph freeway cruise. BUT, the HX's lean burn will work way down at 25 mph. And I have found that my DX loves the 4th gear down to 25mph and fifth gear way down to 35mph. I get great instant mpg numbers (like 70 or 80+ mpg) and a lean AFR in my DX at those speeds in those gears. So depending on the specifics of your route, you might perfect some cool low speed lean burn cruising in 4th and 5th. That would be quite cool.
