Old 07-15-2015, 11:28 AM   #20 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
separate thread?
Originally Posted by GotToyota View Post
Question: So since I bought the car I have had issues with the idle occasionally dipping and sometimes stalling. The idle doesn't bounce, and I've replaced the throttle body gasket, map sensor o-ring, all the vacuum hoses except the lower PCV hose, PCV valve, upper PCV valve hose, distributor cap/rotor, spark plugs and adjusted the idle according to the service manual.
Is it possible that the lower PCV hose is the culprit? It's the only hose I haven't replaced. I did replace the PCV grommet that is at the breather chamber as well but the PCV valve that goes there is questionable, I wonder if I should replace it also?
Doesn't show the part on here but I'm wondering if #2 is the same as the upper PCV valve (#6 in the diagram, part number 17130-PM6-003).
Honda Automotive Parts
I would recommend posting this question as a new thread in the off-topic tech sub-forum. Might get better response there. Personally, I am inexperienced with the PCV. But we have some civic owners with lots of experience who might not notice this question in a thread with this title. Hope that helps.
